Results 1 to 9 of 9
Thread: ok, after first full detail i wasn't that satisfied
    Mar 2006
    12
    ok...the process and products i used didn't really satisfied me. my main goal was to remove all the bird, water etchings and all the spiderweb swirls, so a couple people mentioned about meguiars color x, which i bought. i also bought mothers seal and glaze phase 2. well...turn out color x didn't get rid of the bird and water etchings and swirls, so now i have to buy scratch x. this is my normal process:
    - wash with meguiars gold car shampoo
    - dry using 100% cotton towels
    - meguiars color x
    - mothers sealant and glaze phase 2
    - final wax with meguiars gold liquid wax
    since im gonna buy sratch x, where would that replace in my current process, im guessing it would replace color x. also, some people mentioned to me that using meguiars gold liquid wax is not neccessary when using mothers sealant and glaze...is that true? also at my local autozone, they have meguiars #7 and 27. which of these protects the best and makes the vechicle have a deep wet look, and lasts a while?
    Registered Member Pete-FWA's Avatar
    Oct 2005
    546
    18
    ColorX IS a wax (Last Step Product--LSP) with some cleaning ability and a polish. It's designed to be a one step product. You'll see far better results if you work it on the finish, not just wipe on/wipe off. Since it's a wax, it will last far longer than just a polish alone.
    If ColorX didn't remove your paint defects, then ScratchX is a good product to try.
    Do a search here on ScratchX. It's a great product if you work it well. It is NOT a wipe on/wipe off product either. Unfortunately, with your finish's defects, nothing will remedy them without some extra effort.
    With your process, you're duplicating some of your efforts. ColorX and Gold Class are both waxes (LSPs) so those are generally the last product you'd use in a detailing session.
    You mention using two different waxes.
    The Mothers product has some cleaner in it. Using it after using a wax will remove the wax you applied on the step prior. Now you need to rewax/seal the surface. Their glaze/sealer is designed to get a finish in nice shape ready for a coat of pure wax/sealant (one without any cleaners in it).
    After success with ScratchX, you could apply either the Gold Class or the ColorX to polish and seal your finish.
    What I've typed is a few answers and comments related to your questions. This should start the discussion and get some other people to post. Depending on the specific condition of your finish, they may or may not remove everything.
    See the big picture, enjoy the details
    Oct 2005
    546
    18
    Re: ok, after first full detail i wasn't that satisfied
    M07 is a pure polish; that is, it has no cleaning ability. It does, however, give very deep gloss on a properly cleaned surface. It does not last as an LSP; you'll need to coat it with a wax or sealant to keep the paint protected.
    With 27, do you mean #26 High-Tech Yellow Wax? If so, this is a great LSP. It has no cleaning ability, so it won't remove M07 or another polish that you use. It has good durability and looks good on all color paints and clear coats.
    Des Moines, Iowa
    38
    5,605
    75
    Sorry to hear you didn't have the results you expected. Lets see if we can help you out. Pete mentioned ScratchX assuming you are applying all by hand sounds like it may be your best bet. Like Pete mentioned it will take some work.
    Here is a post that may help you out: How To Remove Swirls By Hand
    Here is another for you: How to remove a defect by hand with ScratchX
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    Mar 2006
    12
    thanks for your reply guys, it was really confusing at first, but now i think its understandable, so color x is a lsp only right? i guess i will be buying sratch x then. it was a waste of money then since i have 3 lsp (mothers sealant and glaze, mothers gold class wax and color x) i guess ill get M07 since its a pure polish. I guess this will be my new upcoming process if i do buy those 2 products...
    - wash, meguiars gold glass shampoo
    - dry, 100% terry towels
    - pure polish, with M07
    - cleaner, scratch x
    - wax, 3 choices (mothers sealant and glaze, mothers gold glass wax or color x)
    please someone tell me if this is correct...
    also, does color x, mothers sealant and glaze bead or sheet water? and out of these 2 offer the best protection giving the car a deep wet look?
    Oct 2005
    546
    18
    It is an LSP, but it ALSO has cleaning and shining/polishing capabilities. It's truly a one-step for getting all 3 done.
    Oct 2005
    546
    18
    Since M07 does no cleaning and only adds gloss to whatever surface, use it AFTER your ScratchX and before your LSP choice. In general, cleaners are going to remove polishes.
    Also, reverse the order on the cleaner and polish such as:
    ---Wash
    ---Dry
    ---Cleaner (ScratchX)
    ---Polish/Glaze....M07 OR Mothers Sealant and Glaze
    ---LSP...Gold Class Wax
    (I'm sticking with the products you've mentioned.) OR---->
    To keep it simpler, at least to start...
    Since you already have ColorX, I'd suggest just using the cleaning properties of ScratchX, then the lighter cleaning/polish/LSP(wax) effect of ColorX. Just use those two. See how you like the results.
    ---wash
    ---dry
    ---ScratchX
    ---ColorX
    Mar 2006
    12
    ---wash
    ---dry
    ---ScratchX
    ---ColorX
    thanks, ill try that...
    Registered Member pepseeboy's Avatar
    May 2005
    20
    I dont know if you've heard of the 5 steps to detailing,
    Wash
    Evaluate
    Clay
    Polish
    Wax
    If you cars are not completely clean your polishes will not be as effective, you need to get all the contaminants out of the paint by claying, after claying you will have a smooth finish to work with and your efforts will show quicker if your doing it by hand.
  1. first full detail
    By livinahighlife in forum Detailing 101
    Last Post: Jan 9th, 2009, 04:42 PM
  2. Full detail on the Cobalt
    By JG_Detailing in forum Show Off Your Latest Detail Work
    Last Post: Jul 21st, 2008, 11:49 AM
  3. ??? about full detail
    By WyldV6 in forum Detailing 101
    Last Post: Dec 4th, 2005, 03:14 AM
  4. first full detail
    By wingzer0 in forum Detailing 101
    Last Post: Sep 27th, 2005, 02:45 PM
  5. What other products do i need for full detail?
    By 99ITR_SC in forum Detailing 101
    Last Post: Apr 15th, 2004, 03:00 PM
