The Aggressiveness Order of SMAT Products - This might surprise you!
If you're referring to "non-abrasive" and "contains no abrasives" we've already talked about that, but maybe this will clear it up:
"Contains no abrasives" would indicate that the product literally contains no abrasive particles and therefore either cleans the paint chemically (Deep Crystal Paint Cleaner functioned this way, primarily) or does not clean the paint at all (Deep Crystal Polish, for example).
"Non-abrasive", specifically in the case of SwirlX, refers to the fact the abrasives in the product are very specialized and will not scratch, mar, haze or otherwise have a negative impact on the appearance of the finish. To the general consumer (ie, folks who aren't as Car Crazy as MOL members) the word "abrasive" carries a negative connotation - they see that word and immediately think it's going to hurt the paint.
About the Swirl X, just wanna ask which pad is the best to use to remove swirls? Is it the red or yellow pad? Im currently using the DAPS.
If you have both, try the least agressive method first (i.e. the yellow pad) on a test spot and see if that does the job.
If not, step up to the red.
