How much water do you guys use to wash your car? I am talking about in your WASH bucket. First, I used to use 4 gallons (4 ounces of car wash solution), then every time I am finished with my car wash, I still have plenty of car wash "solution." So, I started trying 3 gallons (3 ounces of car wash solution), then I only have a bit of car wash solution left after each car wash. I am using a Grit Guard in this wash bucket. Am I risking of contaminating my wash solution faster? Or NO, because I am using a Grit Guard? Thanks!
Wasting car wash solution
Re: Wasting car wash solution
Are you using two buckets, with a Grit Guard in the rinse bucket also?
If so, then I would not worry about the soap, and you can use as little as you like. 3 gallons would be fine.2017 Subaru WRX Premium - WR Blue
For my wheels and tires, I use two gallons of water w/ two ounces of Deep Crystal Car Wash.
For the rest of the car, I use three gallons of water w/ three ounces of whatever car shampoo I am presently using (at the moment I am working myself through Megs' Wash & Wax). Three gallons seems to be sufficient, even for the CR-V.Swirls hide in the black molecular depths, only waiting for the right time to emerge and destroy your sanity.
--Al Kimel
Originally posted by EPHIOS View PostI am using a Grit Guard in this wash bucket. Am I risking of contaminating my wash solution faster? Or NO, because I am using a Grit Guard? Thanks!
Ideally, you should be using 2 buckets. One for wash soap/water and one with clean rinse water. If you only have one Grit Guard, you should put it in the rinse water bucket.
Likely part of the reason you are so much soapy water is due to the fact that you are not using a 2 bucket method.
Rinse your wash mitt in the rinse bucket and lightly wring it out. Then pick up soapy solution from your wash bucket.
You can give your vehicle a slight spray with the hose just prior to using the wash mitt on it. I'm always spraying my vehicle as I go to avoid water spots.
You should be able to wash your vehicle with 2 gal. of wash soap/water max. and that's with a Grit Guard in the bottom. If the Grit Guard is in your rinse bucket you might even be able to wash you vehicle with 1 gal. of wash soap/water
Anyone have a link on where i can get a grit gaurd?? I use the two bucket method but never knew of a grit gaurd.Am i obsessed?? A car is the second biggest financial investment for most people, why not keep it looking better than new?
Originally posted by EPHIOS View PostI am using the TWO BUCKET method with two grit guards.
Here is a trick that I use to use very little wash water without scratching my black truck. I wash my vehicle with 10 microfiber clothes. I use a new cloth one on each panel. I never contaminate my wash water. Only fresh clean clothes ever go into the wash bucket.
I then throw the used microfibers into my rinse bucket and there they can sit until I do laundry.
I hope that helps.
