Life Span of backing plate
Results 1 to 6 of 6
Thread: Life Span of backing plate
    Feb 2005
    115
    16
    Hey guys,
    I was wondering what is the lifespan of a meguiars backing plate for the G-100? Will it typically go through several pads? Also when putting the backing plate on the G-100, once the backing plate stopped on the spindle from hand turning I gave it an extra little tug, should this be sufficient to keeping the backing plate in place and will I need to check it or retighten it every so often?
    Kevin
    Apr 2004
    Port St Lucie FL
    1,230
    27
    Its me again.
    1. I was wondering what is the lifespan of a meguiars backing plate for the G-100? Almost one year and no problems.
    2. Will it typically go through several pads? Not sure about the question. Like literally go through the pad not normally.
    3. Also when putting the backing plate on the G-100, once the backing plate stopped on the spindle from hand turning I gave it an extra little tug, should this be sufficient to keeping the backing plate in place and will I need to check it or retighten it every so often? I have yet to tighten or snug up my backing plate after the initial installation.
    Feb 2005
    115
    16
    Thanks Again Scrub!
    What I meant about the second question is will it last long enough that I will probably wear out a few 8006 pads before I will the backing plate!
    Car Crazy Enthusiast DETLMAN's Avatar
    369
    19
    You should be able to wear out many many pads before you have to replace your backing plate. I have one plate that is probably 3 years old and has gone through a couple dozen pads.
    If you dont play you CANT win!
    65
    15
    My Meguiar's backing plate lasted about 5 car's worth of detailing.
    The velcro won't hold a pad any longer. If I pick up the machine from the car, the pad will fall off. It does grip it good enough to work, I just have to be careful when lifting the machine from the car.
    I need to buy another one but I'm afraid the next Meguiar's backing plate won't last any longer than the first.
    It could be I just got a bad one so I'll probably buy one more and give it a try.
    Registered Member KTruck's Avatar
    Apr 2004
    246
    17
    Hi:
    Can not speak for Meguiar's.
    Call customer service and they will help you. Apparently some plates have a problem holding the pad for some reason.
    Regards,
    KTruck
  1. Backing plate
    By TRIPOWER1 in forum Machines - The Dual Action Polisher
    Last Post: May 15th, 2008, 03:02 PM
  2. Anyone use the pc backing plate
    By kboxer in forum Machines - The Dual Action Polisher
    Last Post: Oct 8th, 2006, 04:01 PM
  3. Backing Plate
    By Mister B in forum Detailing 101
    Last Post: Jul 26th, 2006, 05:47 PM
  4. Backing plate(s)
    By Mort Corey in forum Machines - The Dual Action Polisher
    Last Post: Mar 28th, 2006, 08:19 AM
  5. Backing plate Q
    By Don in forum Machines - The Dual Action Polisher
    Last Post: Feb 21st, 2005, 08:27 PM
