White Wax
  • I thought as whitewax is new, meg might have made the all the new waxes not to stain plastic . Just like the ultimate wax...
    • Re: White Wax
      It is only the Ult. Liquid that does not stain, and Ult Quick Wax / Gold Class Spray Waxes.
      • Re: White Wax
        Hi all
        Just tested white wax on my Honda yesterday - great results, but as the paint was so dirty I went with UC anyways, and plan to maintain using white wax instead. Will try to post some photos I grabbed on my phone later.
        My problem is I can't seem to get white wax to spread thin and evenly the way UWL does - I end up with a sort of "smearing" like the pad is "skipping" over tiny sections of paint rather than gliding over it. Am I applying it wrong? Not enough product? Linear or circular motion? Also doesn't seem to "dry". Does the swipe test apply to white wax?
        Otherwise the wax cleans very well. Just want to know if its more difficult to apply and remove than UWL or if I'm using it wrong?
        Additional info: temp was approx 30C/85F, relative humidity probably around 75%, worked in the shade.
        Thanks!
        • Re: White Wax
          Were you applying it by hand or machine? Was the surface properly washed and clayed?
          • Re: White Wax
            Washed with Gold Class, clayed, and compounded, all by hand. White wax applied by hand with the included applicator. Funny thing is the product seemed to spread better on my test panel that had not been polished with Ultimate Compound.
            • Re: White Wax
              My questions are because I ran into a few issues during the application process, and while the results speak for themselves, it would be much nicer if things went more smoothly with the white wax on my next application. Apologies for the iPhone pics.
              White Wax on left, Ultimate Compound on right (light is coming from the right side of the image, the results for white wax and compound were very close in reality)
              All the crunk on the paint is literally the residue from 3 weeks of constant rain.
              Results (white wax + UW on the hood):
              And the hood after a rainstorm:
              • Re: White Wax
                Maybe almost spreading too easily if the surface was already cleaned?
                • Re: White Wax
                  Interesting thought. After two weeks constant rain I just retested it, still the same issue. Doesn't go on smooth on the first pass, but after a couple straight line passes with a little more pressure it smooths out. Maybe I just need to apply more product with more pressure.
                  • Re: White Wax
                    Nice job on the Honduh, lol.
                    I've use a whole tube of WW on abute 5 cars/trucks and haven't had these problems.
                    So I'm going to say you need to tweak your technique.
                    More/less product, pressure, work area.
                    You need to find the sweet spot for your paint.
                    DetailingByM.com
                    • Re: White Wax
                      Sorry guys, new problem with white wax.
                      I've resorted to using some more product - makes it easier to apply. But its drying on me. I try to spread it thin, though not as thin as UWL. The instructions ay I'm supposed to let White Wax dried to a haze, but its so dry I can't remove it - even with Quik Detailer - and now appears to have left a bunch of swirls on the hood. Help?
                      I hope to be able to fix that with Ultimate Compound next week (used it twice and got pretty decent results - hard to tell on a white car though), but I think I'll be using white wax as a WIWO cleaner topped with UWL from now...
                      • Originally posted by blackstripe77:535914
                        I've resorted to using some more product - ...
                        There's your problem. Everyone does this. You don't need to do that. It causes problems *** your finding out. Use WW to remove it. LIKE REMOVE A LIKE.
                        DetailingByM.com
                        • Re: White Wax
                          I have also found application/removal of White Wax less than satisfying. It is so gritty that you really have to do a perfect job, or it's almost that you feel it left behind.
                          It does have some nice capabilities for removal of defects, but it's no longer a favorite of mine unless for a small spot.
                          • Re: White Wax
                            another problem with removal of wax is the cleanliness of the paint.
                            Claying only remove "surface" contaminates. The paint is still dirty. So if you have dirty paint and you apply a cleaner wax to it WITHOUT working the product into the paint and "clean" it, then the wax will defiantly stick to the dirty paint.
                            You need mechanical power to properly work a cleaner paint "into" the paint.
                            I never have removal problem of any wax, but I'm very experienced.
                            So work your areas very well and you'll see a big difference.
                            DetailingByM.com
                            • Re: White Wax
                              I agree with that, if you work the white wax more, it does remove much easier. Therefore, we should probably just remember, if you're going to use white wax, put in the effort. If you aren't going to put in the effort and want to slop something on there, use something else.
                              • Re: White Wax
                                Thread Revival.
                                At the suggestion of the Meguiar's Hotline, I bought WW last fall when it was time to do a wash/clay/wax on my truck and the wife's new Impreza (both silver, both DD).
                                It seemed to work pretty well, but I don't have the trained eye of some others. I'm using a Ryobi 6" ROB with a MF bonnet.
                                Here's my question. I have a usable amount of NXT 2.0 left over and I was wondering if I could use it to top off the WW or if there is a better use for it somewhere in the mix.
                                Thanks.
                                Jeff in Flagstaff
                                Reduce, Re-Use, Recycle
