We sort of teased this last year, but for 2013 this new system is a definite go, and you'll be seeing a lot of promotion for it online in the very near future, including a Quik Tips Video scheduled for launch in the next couple of weeks.
Product Attributes:
- Superior, patented engineering
- Heavy duty & multi-function
- For corded 3/8 - 1/2" drills with 1,500 - 2,500 rpms range
- Power System tool w/yellow polishing pad
- A versatile, expandable, paint care platform
- Multi-tasker, not a single-function tool
Solutions: DA Power Packs
- At launch, 3 solution-based kits
- Paint correction (compound & cutting pad)
- Paint polishing (polish & polishing pad)
- Wax application (wax & finishing pad)
- More applications to follow
Refills: DA Power Pads
- Replacement 2-pack of pads
- Cutting (paint correction)
- Polishing (paint polishing)
- Finishing (wax application)
- Interior (carpet & upholstery cleaning)
Part Number: G3500
MSRP: $59.99 (tool and one yellow pad)
With this tool, "DA" means both "drill applied" and "dual action", but the dual action is in the form of a forced rotation rather than the free rotating spindle action you might be used to on a polisher like our G110v2. The backing plate is not interchangeable, but the pads are. In fact, the DA Power System makes use of our current line of 4" Soft Buff pads. Drill recommendations are for a corded drill with max speed in the 1500 to 2500 rpm range. The gear reduction ratio in the tool prevents it from spinning at equally high speeds for safety reasons. We also recommend if you have a reversible drill that you use it in the "forward" direction (ie, the setting you would normally use for drilling a hole) rather than "reverse" setting. Most drills run at a slower maximum speed when set to reverse and this will compromise the ability to remove defects from the paint.
The tool is sold with a yellow polishing pad, but no liquid of any kind.
DA Power Pads
1. DA Power Pads - Cutting PadPart Number: G3507
MSRP: $13.99
2. DA Power Pads - Polishing PadPart Number: G3508
MSRP: $13.99
3. DA Power Pads - Finishing PadPart Number: G3509
MSRP: $13.99
For anyone who has shied away from purchasing a buffer either due to fear of using a power tool on their paint, or even just the cost of acquiring a buffer, this is a great alternative to hand applying these products in order to achieve paint correction. For those of you who already have a buffer but find use of a 4" pad to be a bit unwieldy, this system can be a great addition to your detailing arsenal. You might think that using such a tool on a typical power drill might be a bit unwieldy, too, but it is surprisingly ergonomic. The handle is free to rotate to make accessibility easy, and to be able to move it away from mirrors, antennae, etc when buffing, and it's equally accessible to left handed users and right handed users alike. The forced rotation movement of the tool means vibration is also kept very low, adding to the comfort level when used for extended periods of time.
Check out our Quik Tips Video on this system.
