Page 16 of 16 FirstFirst ... 68910111213141516
Results 151 to 160 of 160
Thread: DA Power System
  1. #151
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    4,591
    Rep Power
    53
    Re: DA Power System
    Quote Originally Posted by Rhnos View Post
    claying done, compound done, polishing done.
    today im going to wax
    btw the power pads?
    how to clean them?
    thanks
    Hey Rhnos,
    Happy to hear you are enjoying our DA Power System. To clean the power pads, we recommend washing them in a regular household washing machine, with regular laundry detergent, along with your microfiber towels. They can also be dried in a household dryer machine on low heat. Just don't wash microfiber & cotton terry cloth towels together, because the lint from the terry cloth cotton will stick to the microfibers and make a mess.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
  2. #152
    Registered Member Shootist's Avatar
    Join Date
    Nov 2010
    Location
    Charlotte, NC
    Posts
    43
    Rep Power
    8
    Re: DA Power System
    So, even though I have a PC 7424, DAMF system, etc., the DA Power System has intrigued me for working on small areas. When I saw it on clearance at Wally World for $20 I bought it. Also got (2) additional polishing pads for $5!
    I've used it a few times with M105 & M205. Need to get the red pads for correction. Although the polishing pads worked, I had to make multiple passes.
    However, assuming one is experienced with both DA and Rotary use, why not just use a 3" backing plate and the pads instead of the "system"?
  3. #153
    Mr Sparkle davey g-force's Avatar
    Join Date
    Sep 2005
    Location
    Sydney, Australia
    Posts
    4,269
    Rep Power
    62
    Re: DA Power System
    Quote Originally Posted by Shootist View Post
    I think you're right. If you already have a DA or rotary, you'd just use one of those with a 3" pad for working on small areas.
    The DAPS is more for beginners, those on a budget or those who are apprehensive about using a polisher.
    Quote Originally Posted by Blueline View Post
  4. #154
    Registered Member
    Join Date
    Jan 2018
    Location
    Singapore
    Posts
    6
    Rep Power
    1
    Re: DA Power System
    I'm new to the DA Power System and intend to buy a good cordless drill to go with it (either a Dewalt or Stanley model, with 18V and max 1800 - 2000 rpm).
    I have seen reviews talking about the right speed settings (for cordless drills they should go as high as possible since they will hardly be more powerful than corded ones), but interestingly I have not come across discussion about torque settings before.
    I am rather new to power tools as well, and therefore I would like to ask whether torque settings are a concern when using the DA Power System? And if so, what should roughly be their settings for the 18V tool mentioned above?
    Thanks!!
  5. #155
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    4,591
    Rep Power
    53
    Re: DA Power System
    Quote Originally Posted by EyesWideShut View Post
    Thanks!!
    We recommend using a corded drill, ideally with a max speed of 2500 RPMs. There is a reduction in the attachment, so in order to counter - act that reduction, you want to have a max speed of around 2500 rpms, especially for when using a compound. We recommend max 2800 rpms.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
  6. #156
    Registered Member
    Join Date
    Apr 2016
    Location
    Mauritius
    Posts
    34
    Rep Power
    2
    Re: DA Power System
    is there a recommended speed for compounding, polishing and waxing?
    thanks
  7. #157
    Registered Member
    Join Date
    Jan 2018
    Location
    Singapore
    Posts
    6
    Rep Power
    1
    Re: DA Power System
    Quote Originally Posted by Nick Winn View Post
    Hi Nick, I am aware that it is best to use a corded drill. However, due to constraints in the country I live in (we live in apartments here and we do not have access to power sources in our carparks), I have no choice but to use a cordless drill. I have read reviews that a good 18V cordless drill can give reasonable results, though it may somewhat pale in comparison to a corded drill.
    To go back to my original question, are you aware whether torque settings are a concern when using a cordless drill for the DA Power System, and if they are, what are the recommended settings?
    Thanks in advance !
  8. #158
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    4,591
    Rep Power
    53
    Re: DA Power System
    Thanks in advance !
    We do not have any torque recommendations when it comes to choice of power drill. I do not believe it will take much torque for good performance with our DA Power System, even with moderate pressure while using a compound, it should not take much torque to keep pad spinning.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
  9. #159
    Registered Member
    Join Date
    Jan 2018
    Location
    Singapore
    Posts
    6
    Rep Power
    1
    Re: DA Power System
    Thanks for the prompt reply, Nick. That is what I believe too, as using the drill for detailing is quite different from, say hammering a nail into the wall. I do think that for the purpose of using the DA system, RPM is a more important consideration rather than torque/power. In that regard, would a 14V 2000rpm drill be actually more suitable than a 18V 1500rpm drill (the former has a higher RPM, albeit a lower battery voltage and consequently less torque) ?
  10. #160
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    4,591
    Rep Power
    53
    Re: DA Power System
    Hi, yes, if you have to go cordless, we would recommend the one with the higher RPM. Remember below is the recommended RPM range:
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
Thread Information
Users Browsing this Thread
There are currently 3 users browsing this thread. (1 members and 2 guests)
  1. Doug Thompson
Similar Threads
  1. New Meg Power System Availability?
    By Vettefan in forum Consumer Line - Product Discussion
    Last Post: Jan 26th, 2012, 11:34 AM
  2. Meguiars Dual power system
    By JGdetailing in forum The Break Room
    Last Post: Nov 2nd, 2011, 11:08 AM
  3. Power hand polisher. "Power Pad"
    By Newport Viper in forum New Product Suggestions
    Last Post: Apr 9th, 2006, 08:23 PM
  4. Rotary Power-on Power-off
    By tripper_11 in forum Mastering the Rotary Buffer
    Last Post: Feb 4th, 2005, 12:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
