DA Power System - Page 11
Page 11 of 16 FirstFirst ... 345678910111213141516 LastLast
Results 101 to 110 of 160
Thread: DA Power System
  1. #101
    Still Learning KidDetailer's Avatar
    Nov 2008
    las vegas
    144
    12
    Re: DA Power System
    If i were to use Deep Crystal Pure Polish with the DA system, which pad would I use?
  2. #102
    Sep 2005
    Sydney, Australia
    4,286
    63
    Re: DA Power System
    ^^ I'd say you'd want the black finishing pad for that.
  3. #103
    Nov 2008
    las vegas
    144
    12
    Re: DA Power System
    So I'm assuming the
    Red pad is for moderate/severe paint cleaning such as Ultimate Compound, Scratch X
    yellow pad is for light paint cleaning such as Deep Crystal Paint Cleaner, Swirl X, Ultimate Polish
    Or is yellow pad only really designed for Ultimate Polish?
    Anything that doesn't correct paint such as Pure Polish or the Waxes (except cleaner waxes) would be Black pad?
  4. #104
    38
    19,050
    235
    Re: DA Power System
    That is more or less correct... some things are just by feel/experience, but that would be the idea.
    With a DA Polisher, you don't want the red pad as much, but it can be used more often with the Power System.
  5. #105
    Registered Member kiwiatlarge's Avatar
    New Zealand
    97
    9
    Following on from that, I'm assuming the yellow would be best for most AIO applications, assuming anyone using one would be at the least intending a light clean of the paint.
  6. #106
    38
    19,050
    235
    Re: DA Power System
    Yeah, most likely.
  7. #107
    Nov 2008
    las vegas
    144
    12
    Re: DA Power System
    So Cleaner Wax would go with the yellow pad because of its cleaning ability as well as polish and wax.
    Is the Meguiars Hand applicator pad MEG W0004 the same cut as the yellow pad of the DA system?
    Based on my understanding, most if not all of my jobs usually would just use the Yellow even for cleaning. Its safer to start on the yellow for scratch X, then try the Red if the yellow isn't working.
  8. #108
    38
    19,050
    235
    Re: DA Power System
    1. Well, it is kind of a generalization. But yeah, trying to get the best out of all 3. I am sure there are cases where the others may work better, but just as a starting point.
    2. No, different foam, so I doubt it. And working by hand changes things a lot anyway.
    3. You can, though don't want to go 'overkill' with the mildest methods first. I'd probably pick UC over the ScratchX. And the UC + red pad didn't seem overly strong on the Power System. But can always try a spot with yellow first.
  9. #109
    Registered Member s word's Avatar
    Jul 2012
    west covina
    332
    Re: DA Power System
    I use the Power System regularly on my VW for hard to get spots/piano black trim. Red definitely can be used with UC without being overly harsh. Yellow pads in my experience have minimal cut. Red may be sometimes considered harsh when working with G110v2 and 7" pads but with powersystem it is not.
    Usually I use M105 or M101 with powersystem red pads and sometimes think even that combo is not aggressive enough.
  10. #110
    Apr 2009
    Raleigh NC
    73
    Re: DA Power System
    Will the 3" DAMF DCM3 work with the DAPS? I have a car with some scratches that aren't coming out after several passes with UC and a Burgundy Pad. I read another thread where Mike Stoops reference the DAMF system as a step up in aggressiveness using it with a G110. These scratches aren't really deep and don't catch your nail but they are unsightly.
  1. New Meg Power System Availability?
    By Vettefan in forum Meguiar's Consumer Line Products
    Last Post: Jan 26th, 2012, 11:34 AM
  2. Meguiars Dual power system
    By JGdetailing in forum The Break Room
    Last Post: Nov 2nd, 2011, 11:08 AM
  3. Power hand polisher. "Power Pad"
    By Newport Viper in forum New Product Suggestions
    Last Post: Apr 9th, 2006, 08:23 PM
  4. Rotary Power-on Power-off
    By tripper_11 in forum Machines - The Rotary Polisher
    Last Post: Feb 4th, 2005, 12:09 PM
