DA Power System - Page 12
Page 12 of 16 FirstFirst ... 245678910111213141516 LastLast
Results 111 to 120 of 160
Thread: DA Power System
  1. #111
    Registered Member s word's Avatar
    Jul 2012
    west covina
    332
    Re: DA Power System
    Quote Originally Posted by foilr View Post
    Will the 3" DAMF DCM3 work with the DAPS? I have a car with some scratches that aren't coming out after several passes with UC and a Burgundy Pad. I read another thread where Mike Stoops reference the DAMF system as a step up in aggressiveness using it with a G110. These scratches aren't really deep and don't catch your nail but they are unsightly.
    Wow good question. I think they will fit because of the hook and loop configuration of both pads being used.
    The results you will get may differ because the motion of the DAPS is not the exact same as a DA but I bet you would achieve greater cut than burgundy pad either way.
    Also you could look into increasing the product cut to something like M105 or M101.
    And now when I get home I know exactly the process I am going to try to clean up my piano black finish that is always a nightmare.
  2. #112
    Apr 2013
    Knoxville, TN
    3
    6
    Re: DA Power System
    I used the DA power system three days ago. I drive a Black Tahoe, and the paint was in pretty bad shape because of swirling. I used the tool to put a coat of Meguiar's polish to fight the swirling. Next a did a coat of the new black wax followed by a coat of UW. I must say this car looks slick. However, one of my favorite features to detailing is making the tires shine, especially on a black care. I have always used Meguiar's Hot Shine Tire Coating, and the tires come out looking fantastic. I just bought this Tahoe a couple of months back, and the last two times I applied the spray to the tires it seems that splatters are thrown on the paint of the vehicle the next day after I drive it. I can tell it is from the tires because the wheel wells are covered in it. I only make one pass over the tires when applying. Should I use a different product? Or use a pad and make a pass over the tire? \
    Thanks!
  3. #113
    38
    19,050
    235
    Re: DA Power System
    You can take an older terry cloth and blot/wipe the tire to try to take off some excess product.
  4. #114
    May 2013
    California
    3
    6
    Re: DA Power System
    Hi everyone,
    New to this forum and I just wanted to say that this looks like a great community. I am not new to detailing but am always learning. I have a question about the DA Power System. I recently bought one and used the red cutting pad with Ultimate Compound on a corded drill rated at 4.1 Amps. I found that the system worked great on my black Honda Prelude in increasing the paint's overall clarity and removing oxidation but had almost no effect at all on the swirl marks. I followed the directions, working the compound in a small area. I also followed the work area up with Ultimate Polish using the yellow pad and then finally with Ultimate Wax. I'm confused as to why the swirl marks are still there. Am I doing something wrong? Do I just need a more powerful drill? More pressure? Any input would help greatly. Thank you.
  5. #115
    38
    19,050
    235
    Re: DA Power System
    The first guess would be pressure and speed. Faster speed for the drill, slower speed for your arms.
  6. #116
    May 2013
    California
    3
    6
    Re: DA Power System
    I'm using the drill at max speed, and I tried playing with various pressure levels and still no luck. Is there a minimum power rating that the drill must be? I'm thinking mine might be too weak for the job. Thanks for the reply.
  7. #117
    7,017
    80
    Re: DA Power System
    What speed is your drill? 1800 - 2500 rpm's is recommended for max speed.
    800-854-8073 ext 3845
  8. #118
    May 2013
    California
    3
    6
    Re: DA Power System
    I can't find the speed rating anywhere on it, and I lost the box years ago. It just says 4.1 Amps.
  9. #119
    7,017
    80
    Re: DA Power System
    What manufacturer and model is it? I would imagine you can find the specifications on-line.
  10. #120
    Registered Member JG_Detailing's Avatar
    Apr 2004
    Waynesburg, Pa
    47
    1,799
    36
    Can this system be used with a 1500 cordless power drill. I bought a Dewalt and was gonna use it with the DA power system for waxing and polishing.
  1. New Meg Power System Availability?
    By Vettefan in forum Meguiar's Consumer Line Products
    Last Post: Jan 26th, 2012, 11:34 AM
  2. Meguiars Dual power system
    By JGdetailing in forum The Break Room
    Last Post: Nov 2nd, 2011, 11:08 AM
  3. Power hand polisher. "Power Pad"
    By Newport Viper in forum New Product Suggestions
    Last Post: Apr 9th, 2006, 08:23 PM
  4. Rotary Power-on Power-off
    By tripper_11 in forum Machines - The Rotary Polisher
    Last Post: Feb 4th, 2005, 12:09 PM
