DA Power System - Page 14
Page 14 of 16 FirstFirst ... 4678910111213141516 LastLast
Results 131 to 140 of 160
Thread: DA Power System
  1. #131
    Sep 2005
    Sydney, Australia
    4,286
    63
    Re: DA Power System
    Quote Originally Posted by JOCKTHEGLIDE View Post
  2. #132
    21,386
    1136
    Re: DA Power System
    Love the meguiar stuff....INCREDIBLE.
    "Incredible" describes the car quite well, too! That Charger is gorgeous!
  3. #133
    Registered Member kiwiatlarge's Avatar
    New Zealand
    97
    9
    Re: DA Power System
    Just an extra thumbsup from today for this system from me, a regular car owner, who doesn't detail cars for a living.... I've always been a fan of UC, UP and ULW by hand (even if it should be said my hand my UC applications have always been more for extra strength cleaning and polishing than defect removal... aside from the odd bird poop or scratch, which it has been effective on by hand) ... and I've been a fan of this D/A system and how much it speeds up my application of Ultimate Polish and Ultimate Liquid Wax ever since I bought it..
    Well, today I had my first decent attempt at taking my time on a panel and trying to remove some decent defects... Long story short, last weekend my dog was tied up at home while we were out on a car run, and managed to put some pretty decent scratches up one side of my daily driver (in my avatar) .... I didn't even spot them until I left for work on Monday morning... well, when I got to work I grabbed my car kit out of the back, spray detailed some of the scratched areas, and tested some Scratch-X by hand, just to see what I was in for... Some of them were pretty deep, but I was hopeful I could at least soften most of them.
    So today, one weekend later, I give my car a wash and dry, and try out UC using the burgundy pad slowly on two of the panels... To my suprise I've removed all but the worst of it, and even the worst of it is softened that much, that you will only notice it up close.. given that it is a daily driver which will soon be moving to gravel roads, and has stone chips all over the bonnet, an application of UP and NXT2 later, I'm happy with that...
  4. #134
    Apr 2014
    MD
    41
    5
    Re: DA Power System
    we don't have Meguiar's locally so when i'll need a refill of my pads - can i go for Lake Country 4 inch pads?
  5. #135
    Apr 2016
    Mauritius
    34
    3
    Re: DA Power System
    i just bought the DA Power System.
    now i need the pads and the compound, polish and wax.
    what is the size of the solution (compound, polish or wax) which is in the powerpack?
    i have a hatchback, will this be enough to do the whole car or should i buy the solution and the pads separately because i can see that the size of the solution is around 500ml when on its own.
    please help!
    thanks
  6. #136
    Apr 2016
    Mauritius
    34
    3
    Re: DA Power System
    is it mandatory to use the red pad for compound, the yellow pad for polishing and the black pad for waxing?
    or can i use any power pads at random?
    thanks
  7. #137
    7,017
    80
    Re: DA Power System
    Quote Originally Posted by Rhnos View Post
    thanks
    It is not mandatory but we would not recommend using any product which does not contain abrasives or cleaning ability with the red compounding pad.
    800-854-8073 ext 3845
  8. #138
    Registered Member Mr. Slick's Avatar
    Dec 2015
    Palm Springs
    159
    5
    Re: DA Power System
    Can you use this to correct headlights? What are the steps? maroon with Pastic compound, then yellow with plastic polish? what if you use a foam interface pad and start with wet sanding headlights?
  9. #139
    7,017
    80
    Re: DA Power System
    Quote Originally Posted by Mr. Slick View Post
    In regards to headlight restoration, if you are sanding the headlight, typically a rotary is needed to remove the sanding marks, like a drill or rotary polisher tool. If you are not sanding, and just are trying to remove light oxidation, using the DA Power System with some PlastX on either the polishing or compounding pad would have the ability to remove the light oxidation. We do not approve or recommend this tool for sanding, but we do approve it for use as the first step in our G2000 Perfect Clarity Headlight Restoration Kit.
  10. #140
    Apr 2016
    Mauritius
    34
    3
    Re: DA Power System
    Quote Originally Posted by Nicholas Winn View Post
    thanks for your reply
    i have three yellow power pads ..
    can i use yellow to compound and another yellow to wax?
    products to be used are the ultimate compound ultimate polish and ultimate wax.
    thanks
  1. New Meg Power System Availability?
    By Vettefan in forum Meguiar's Consumer Line Products
    Last Post: Jan 26th, 2012, 11:34 AM
  2. Meguiars Dual power system
    By JGdetailing in forum The Break Room
    Last Post: Nov 2nd, 2011, 11:08 AM
  3. Power hand polisher. "Power Pad"
    By Newport Viper in forum New Product Suggestions
    Last Post: Apr 9th, 2006, 08:23 PM
  4. Rotary Power-on Power-off
    By tripper_11 in forum Machines - The Rotary Polisher
    Last Post: Feb 4th, 2005, 12:09 PM
