DA Power System - Page 15
Page 15 of 16 FirstFirst ... 578910111213141516 LastLast
Results 141 to 150 of 160
Thread: DA Power System
  1. #141
    7,017
    80
    Re: DA Power System
    Quote Originally Posted by Rhnos View Post
    thanks for your reply
    i have three yellow power pads ..
    can i use yellow to compound and another yellow to wax?
    products to be used are the ultimate compound ultimate polish and ultimate wax.
    thanks
    Yes you can use a yellow pad for either the Ultimate Compound, Ultimate Polish, or Ultimate Wax, if needed. Keep in mind if more defect removal is needed, the red compounding pad would be recommended with Ultimate Compound. Ultimate Polish is typically used with the yellow polishing pad. In regards to using a yellow polishing pad for applying Ultimate Wax this is OK, not ideal, but OK to do. Just remember when applying the wax you can move pretty quickly. We typically just do two 50% overlapping passes, one vertical, one horizontal, with light to moderate pressure, and then move to next section.
    800-854-8073 ext 3845
  2. #142
    Apr 2016
    Mauritius
    34
    3
    Re: DA Power System
    Quote Originally Posted by Nicholas Winn View Post
    many thanks for the precious advice.
    after applying the compound, the polish and the wax, which product do you recommend next?
    should i give paint protect a try? or should i simply wash my car and apply quick detailer afterwards.
  3. #143
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    39
    5,357
    60
    Re: DA Power System
    Some sort of protection would be what you want after doing some sort of paint correction. You can go with a carnauba wax or a sealant if you want something more durable and longer lasting (NXT, Ultimate Wax, M21, Paint Protect). It's personal preference.
  4. #144
    Apr 2016
    Mauritius
    34
    3
    Re: DA Power System
    thanks for the tip.
    do you mean i should use either ultimate wax or paint protect after applying the ultimate compound and polish? or should i use the paint protect after applying the ultimate wax?
    thanks
  5. #145
    Sep 2016
    italy treviso
    4
    3
    Re: DA Power System
    I read some post, and you say it's better to use a drill that spins at 1800-2500 rpm but I would like to know which is the best average speed to be used to avoid overheating of the paint and cause damage
  6. #146
    Sep 2016
    italy treviso
    4
    3
    Re: DA Power System
    No answers for my question?
  7. #147
    7,017
    80
    Re: DA Power System
    thanks for the tip.
    thanks
    Hi Rhnos,
    Either Ultimate Wax or Paint Protect after Ultimate Polish. You would not need to do both Ultimate Wax & Paint Protect, just one of the other.
  8. #148
    7,017
    80
    Re: DA Power System
    Quote Originally Posted by gulluwing View Post
    Hi gulluwing,
    We recommend using a drill with this 1800 - 2500 RPM range mainly because there is a reduction in the DA Power System Drill Attachment itself. You want to "counter act" for that reduction by having a higher speed drill in this range, especially when using the DA Power System for compounding. It should be noted that the attachment converts the rotary drill into a forced rotation oscillating DA, and you will not be spinning at these high RPMS because of the reduction in the attachment, so you really don't have to worry about excess heat build up or damage, provide you use good technique : )
    Hope this helps
    - Nick
  9. #149
    Sep 2016
    italy treviso
    4
    3
    Re: DA Power System
    Hi gulluwing,
    Hope this helps
    - Nick
    This helps, thanks a lot and best regards
  10. #150
    Apr 2016
    Mauritius
    34
    3
    Re: DA Power System
    claying done, compound done, polishing done.
    today im going to wax
    btw the power pads?
    how to clean them?
    thanks
  1. New Meg Power System Availability?
    By Vettefan in forum Meguiar's Consumer Line Products
    Last Post: Jan 26th, 2012, 11:34 AM
  2. Meguiars Dual power system
    By JGdetailing in forum The Break Room
    Last Post: Nov 2nd, 2011, 11:08 AM
  3. Power hand polisher. "Power Pad"
    By Newport Viper in forum New Product Suggestions
    Last Post: Apr 9th, 2006, 08:23 PM
  4. Rotary Power-on Power-off
    By tripper_11 in forum Machines - The Rotary Polisher
    Last Post: Feb 4th, 2005, 12:09 PM
