DA Power System - Page 6
Page 6 of 16 FirstFirst 1234567891011121314 ... LastLast
Results 51 to 60 of 160
Thread: DA Power System
  1. #51
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,888
    65
    Re: DA Power System
    Quote Originally Posted by Kingfish73 View Post
    When will we be able to buy this in the stores?
    Both ADS (autodetalingsolutions.net) and AutoGeek (autogeek.net) have DA Power System in stock.
  2. #52
    Registered Member juliom2's Avatar
    Aug 2010
    Puerto Rico
    273
    Exclamation Re: DA Power System
    Very nice, Julio! Have you had a chance to use it yet? We're curious to see how long that cordless drill lasts, and if it has enough power to do any sort of correction. We recommend a corded drill, not cordless, with a max speed between 1500 - 2500 rpm for defect removal, but a good cordless drill just might work for simple waxing of a vehicle. I just picked up a cordless drill and will trying this over the weekend.
    Tool is more than users could expect from a drill attachment. I was very surprised of how well it worked with my cordless drill to tackle small defects.
    Tremendous power transfer that gets the pad really working on the surface. Trigger response is accurate to ensure control at all times.
    Applying wax is very easy with the DA Power System (and has a high fun factor also).
  3. #53
    Aug 2010
    Puerto Rico
    273
    Re: DA Power System
    Drill in hi speed setting...
  4. #54
    38
    19,050
    235
    Re: DA Power System
    How hard were you pressing down for defect removal?
  5. #55
    Aug 2010
    Puerto Rico
    273
    Re: DA Power System
    I would estimate 4 to 7 pounds in occasions, since is a forced rotation device
    you dont want to apply a lot of pressure primarily because is not needed
    to exceed the pressure to be worked on the surface thanks to the efficiency of the planetary gears of the device, in addition
    excess pressure will compromise the control of the pass with the DA Power System.
  6. #56
    38
    19,050
    235
    Re: DA Power System
    Looking forward to using it on defects... will be great if it doesnt even take much pressure to accomplish that.
  7. #57
    21,386
    1136
    Re: DA Power System
    Just an FYI - I did a little test over the weekend with an 18v cordless drill and easily waxed my entire car on a single charge. I used NXT Tech Wax 2.0 paste and a black finishing pad. It spread quickly, very thin and even, and it took almost no effort. With a powerful cordless drill I'm sure you could easily to some small spot correction, but the extra pressure required for defect removal, and the extra time involved in doing so over a given area, would most likely drain the battery long before you could finish the entire vehicle. Stick with a corded drill for full vehicle correction, no doubt about it. But if you like paste waxes, this is super convenient for machine applying them with ease.
  8. #58
    Aug 2004
    Glendale, AZ
    34
    2,962
    50
    Re: DA Power System
    Just an FYI - I did a little test over the weekend with an 18v cordless drill and easily waxed my entire car on a single charge. I used NXT Tech Wax 2.0 paste and a black finishing pad. It spread quickly, very thin and even, and it took almost no effort. But if you like paste waxes, this is super convenient for machine applying them with ease.
    That's the exact why I'm going to buy this tool. I seriously cannot wait.
  9. #59
    Aug 2010
    Puerto Rico
    273
    for spot correction; is better to set the drill at a low speed and work the compound as you would with a DA polisher.
    Small spot and a few passes...
    work the compound and inspect the surface as you go...
    finish with your favorite wax....
  10. #60
    Registered Member DAN THA MAN's Avatar
    Dec 2012
    Leeds, AL
    5
    7
    Re: DA Power System
    So Mike, when will this be available for purchase? I assume it's not out yet because most sites I check out show it as "out of stock" or estimate shipping by the end of January 2013. I really really want one but I need it now. I am a man without a buffer. Help! LOL Can't wait to get my paws on it. Also do you know if there will be an all-in-one super saver pack (DA Power System + Compound Kit + Polish Kit + Wax Kit), and if so how much? Thanks
  1. New Meg Power System Availability?
    By Vettefan in forum Meguiar's Consumer Line Products
    Last Post: Jan 26th, 2012, 11:34 AM
  2. Meguiars Dual power system
    By JGdetailing in forum The Break Room
    Last Post: Nov 2nd, 2011, 11:08 AM
  3. Power hand polisher. "Power Pad"
    By Newport Viper in forum New Product Suggestions
    Last Post: Apr 9th, 2006, 08:23 PM
  4. Rotary Power-on Power-off
    By tripper_11 in forum Machines - The Rotary Polisher
    Last Post: Feb 4th, 2005, 12:09 PM
