I was about to throw out one of my practice hoods and decided to make this video first. Enjoy!
How to burn paint
How to burn paint
Last edited by Markus Kleis; Oct 13, 2013, 09:41 PM. Reason: Moved to the appropriate forum and embeddedTags: None
Re: How to burn paint
Good vid--thanks for taking the time to make it and share. Further proof that improper technique such as leaving the polisher still too long or catching an edge is what damages a finish.
A question for you: Do you buff with the small pads at 1000 RPM? Are you able to achieve correction that way? While in my peak buffing speeds (not breaking down the polish) I use 1000-1200 on the 8" pads and bump it almost to 1600 when down in the 5" range.Brandon
Custom Cleaning Concepts, LLC
(435) 249-4CCC (4222)
"When you want your ride as clean as can be, you need to call CCC!"
