self car wash rinse + Meguiars Ultimate Wash & Wax Anywhere, is it good enough?
Results 1 to 9 of 9
Thread: self car wash rinse + Meguiars Ultimate Wash & Wax Anywhere, is it good enough?
    Feb 2014
    michigan
    4
    6
    i dont have access to water, so I did a self car wash which basically rinses my car and then quickly drive home, dry out using towel and then apply ultimate wash and wax.
    is it good enough? should i put ultimate wax finally?
    thank you
    Cadillac enthusiast Eldorado2k's Avatar
    Jan 2014
    Los Angeles, Ca
    40
    1,257
    19
    If I were you I'd do a baggie test to see if you need to clay to make sure your paint is completly smooth prior to applying wax.
    Feb 2014
    michigan
    4
    6
    Re: self car wash rinse + Meguiars Ultimate Wash & Wax Anywhere, is it good enough?
    thanks, and since this is a new car, is it required to apply clay? it's very time-consuming.
    if i dont want to apply clay but just use high pressure water to pre-wash and rinse every two weeks, how often do i have to do the claying?
    thanks
    Jan 2014
    Los Angeles, Ca
    40
    1,257
    19
    From what I've heard [from alot of people] even new cars are in need of a claybar and have a rough finish on the paint.
    Claying doesn't take too long at all. Everything you need is provided in the Meguiars clay kit [it comes with 2 80gram bars] and can be done fairly quick.. Another reason for doing it is that your wax will apply/perform much better if applied to a smooth finish.
    Once you've applied your wax to a well preped [clayed] surface, you may not need to clay for quite a while as long as your wax remains intact to protect your finish. Using a good spray wax like Ultimate Quik Wax after every wash can help extend the longevity of your innitial application of Ultimate Liquid/Paste Wax.
    IMO it's worth not skipping any of the steps because if done properly, the maintaining of a great looking finish becomes so much easier. Not to mention you want to keep your new car looking new!
    38
    19,050
    235
    If it hasnt been clayed, it probably should be.... not sure about time consuming. If it is bad, then yes.. but should just be wiping your hand over the surface really.
    As far as your process... I would drive home, then use the W&WA, then dry.
    Feb 2014
    michigan
    4
    6
    thank you, i may consider doing once...
    for the 80gram clay bar, how many times can each of them be used as long as i dont drop it to the floor....
    Sep 2005
    Sydney, Australia
    4,286
    63
    ^^ That really depends on a lot of factors, but an average might be 10 - 20 cars...
    No need to dry before using UWWA, since in your case there would not be much water left on the car anyway.
    Clay it once initially, then maybe every 12 months.
    Apply UW maybe every 3 months.
    38
    19,050
    235
    I cut the bar into smaller pieces incase I drop them...
    Registered Member larry0071's Avatar
    Aug 2013
    Pittsburgh, PA (Beaver County)
    181
    7
    Claying is not a long or tedious process. It takes a bit more time than washing, but it's not a labor intensive deal or a really long deal. Especially on a small car, 30 minutes to an hour.
    Doing the best I can with what I've got.
  1. Review: Meguiars Ultimate Wash and Wax Anywhere
    By Shawn T. in forum Meguiar's Consumer Line Products
    Last Post: Jul 1st, 2015, 02:16 PM
  2. ?? Does Meguiars make a wash rinse aide ...
    By timberland in forum Meguiar's Consumer Line Products
    Last Post: Dec 12th, 2012, 02:41 AM
  3. Gold Class Car Wash Shampoo / Conditioner vs Meguiar's Ultimate Wash & Wax
    By koicrazy98 in forum Meguiar's Consumer Line Products
    Last Post: Jul 24th, 2012, 05:15 PM
  4. My Pontiac after going over it with Meguiars Ultimate wash, polish and wax...
    By strader327 in forum Show Off Your Latest Detail Work
    Last Post: Jul 19th, 2011, 10:06 PM
  5. How-to Wash your car with a Rinse-less Wash System [video]
    By Markus Kleis in forum Detailing 101
    Last Post: Apr 17th, 2010, 12:09 PM
