Meguiar's Extreme Marine - Water Spot Detailer
Results 1 to 5 of 5
Thread: Meguiar's Extreme Marine - Water Spot Detailer
    7,017
    80
    Work Less. Play More!
    Extreme Watercraft deserve nothing but the most advanced products on the market to ensure the best in appearance and performance. Meguiar's Extreme Marine Products are precision engineered to maximize your extreme marine lifestyle with incredible results in less time.
    Designed to maximize time spent enjoying your watercraft, Meguiar's Extreme Marine - Water Spot Detailer combines power water spot removal with cleaning and protection into one easy-to-use spray-and-wipe solution. This innovative formula is safe across most marine surfaces and leaves a durable glossy, water bead-making layer of protection.
    Features:
    • Advanced chemistry safely removes hard water spots, cleans & leaves lasting protection in one easy step.
    • Safe on painted, fiberglass, gel coat, colored plastic, glass, chrome and stainless steel surfaces.
    • Durable polymer protection boosts existing wax protection, intensifying beads and minimizing future spotting.
    • Pineapple Lemon Scent
    Details:
    • Product Name: Meguiar's Extreme Marine - Water Spot Detailer
    • Part #:M180232
    • MSRP: $19.99 USD
    • Size: 32 fl oz
    Available Now through your favorite Meguiar's Marine/RV Product Distributor!
    800-854-8073 ext 3845
    Sep 2005
    Sydney, Australia
    4,286
    63
    Re: Meguiar's Extreme Marine - Water Spot Detailer
    Interesting...
    So will this remove below-surface water spots; i.e. is it abrasive in any way?
    7,017
    80
    Interesting...
    Hi Davey,
    So there are basically two ways to address water spots, either by use of abrasive or chemical cleaners. Extreme Marine Water Spot Detailer addresses & removes water spots by use of chemical cleaners. It is not abrasive. There are always going to be cases of heavy water spots stains which needed to be removed by abrasive, like a compound, but Extreme Marine Water Spot Detailer can handle light to moderate water spots.
    We also would like to mention we OK this product for use on automotive paint.
    There are two methods of application:
    For light water spots, the product can be sprayed directly onto a microfiber towel, and then applied to a cool surface.
    For moderate water spots, the product can be sprayed directly onto the surface to dwell, and then can be removed with a microfiber towel. (product should not dry on surface or be used in the sun.)
    Be sure to always read and follow the directions on the product labeling prior to use.
    7,017
    80
    Sep 2005
    Sydney, Australia
    4,286
    63
    Hi Davey,
    Understood... thanks for the clarification!
  1. Meguiar's Extreme Marine - Multi-Surface Cleaner
    By Nick Winn in forum Meguiar's Product Introduction Threads
    Last Post: Nov 1st, 2017, 08:06 AM
  2. Meguiar's Water Spot Remover
    By JeremyD in forum Detailing 101
    Last Post: Feb 3rd, 2015, 05:19 PM
  3. Should Meguiar's sell a water spot preventer?
    By akimel in forum New Product Suggestions
    Last Post: Jul 20th, 2009, 10:53 AM
  4. Hard water spot remover from Marine line
    By barry in forum Detailing 101
    Last Post: May 29th, 2009, 02:00 PM
  5. marine line Water spot remover
    By Chex in forum Detailing 101
    Last Post: Oct 6th, 2006, 07:10 AM
