Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Not satisfied with clay
    Nov 2017
    FL
    Hello,
    I'm doing a paint correction on my black Chrysler 300. It
    Nov 2017
    FL
    Re: Not satisfied with clay
    It’s got the typical scratches swirls etc. I e finished the trunk and rear bumper so far as I’m doing the car a little each day to make sure I dedicate enough time to each panel.
    My issue is that I’m not satisfied with the result of my clay jobs. I have two white Meguiars clay bars that both came from kits. I realized early on that I was being too soft with the clay and I changed up my technique to be a little more aggressive. However despite claying the same panel 3+ times I still feel (and hear) a lot of contamination. I went ahead and did my best on the trunk and rear bumper and finished off with a compound/polish/wax (which turned out awesome and fixed a lot of issues) but as I start my rear Fender I’m just not satisfied continuing with the contaminants I still feel.
    i use a heavy amount of detail spray. But after the first pass I no longer pick up anything on the clay but I can still feel it with the bag test.
    I did order some aggressive clay but I feel a little intimidated to use it, I don’t want to mess up the finish. Obviously I will be following the clay job with compound and polish but I’m not sure if it’s too big of a leap for a newb like me.
    Any advice?
    4,588
    53
    Sorry to hear about the trouble. A couple thoughts:
    I noticed you mentioned you are using a heavy amount of detail spray. First, which detail spray are you using as a lubricant? We would not say a heavy amount of detail spray is necessary for clay bar lubrication. As far as amount? Most easy way to describe how much to use is just enough to keep the clay moving. It's possible you are creating an ultra slick surface with the abundance of detail spray, thus not allowing the clay to be as effective. Not saying this is the problem, just a possibility.
    The clay bar in our G1016 Smooth Surface Clay Kit is considered mild and works great majority of the time, but there are situations where a more aggressive clay bar can work quicker. Depending on the level of contaminants present on the vehicle, amount of time contaminants have been present on paint, when clay was last used, etc. You may get quicker results going with a more aggressive clay bar. I'm not necessarily saying go straight to our C2100 Professional Aggressive Detailing Clay but our C2000 Professional Mild Detailing Clay is a step above in aggressiveness compared to our G1016 Smooth Surface Clay Kit. This would be our next recommendation, if you determine this is what you would like to next.
    Overall if you are unsatisfied with our purchase of our Smooth Surface Clay Kit, you are welcome to contact our Solutions Hub at 800-347-5700 or customercare@meguiars.com to see what they can work out with you in regards to refund/replacement.
    Good luck & feel free to post further questions, keep us updated. Hope this helps.
    800-854-8073 ext 3845
    Nov 2017
    FL
    Thanks for the quick reply. I will definitely try using less detail spray and see how that works out for me. I am using Meguiars ultimate detailing spray to lubricate the clay. I appreciate the offer but no need for a refund or replacement as I don’t believe it’s a faulty product. It’s either user error or the contaminants need a little more aggressive action
    Dec 2017
    Pennsylvania
    54
    Have you considered applying trizact 3000 wet paper (foam pad or sanding block), followed by M105, M205 ?
    Registered Member PPLd's Avatar
    Jun 2010
    Hong Kong
    29
    159
    9
    Quote Originally Posted by RX300 View Post
    Hello my friend,
    I remember reading it somewhere that the UQD was too slick and not recommended as clay lube.
    Suggest you may give the Quik Detailer that come with your clay kit a try and see how that turns out.
    Dennis
    Nissan Fuga | 日產 風雅 | 日産 フーガ
    Jan 2007
    Rochester Hills, Michigan
    425
    16
    Quote Originally Posted by PPLd View Post
    Hello my friend,
    Yep, UQD contains polymer protective ingredients, which will impede the clay's performance.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    38
    5,157
    57
    Hello my friend,
    This is correct. This was mentioned long ago. I would try using regular detail spray.
    Quote Originally Posted by syswizard View Post
    I would not go that route just yet. Least aggressive method first would be my recommendation. No sense in removing clear if not needed.
    Aug 2010
    Memphis, TN ~ USA 1
    446
    12
    Forgo the detail spray. Clay during your wash process
    Wash Panel > Rinse > Clay > Rinse
    If you have Industrial grade paint overspray, you'll need to either get a more aggressive clay or something like the Speedy Prep towel. You could also wetsand, but you'll be doing a ton of work that's not necessary
    Apr 2007
    US
    1,027
    21
    Quote Originally Posted by Flash Gordon View Post
    I have often thought of doing that but was worried that water alone would not provide enough lubrication. My thoughts are that using expensive detail spray to clay was such a waste of money. In fact, I used to buy some cheap off Meguiar's brand detailer to clay. I might just try your technique for my next clay, unless anyone comes up with a good reason not to.
  1. Difference between Pro C2000 Mild clay and the consumer smooth clay kit ?
    By thedoc46 in forum Professional Line - Mirror Glaze & Detailer Line Product Discussion
    Last Post: May 13th, 2015, 10:59 PM
  2. extremely satisfied
    By Bjkearns in forum The Dual Action Polisher
    Last Post: Sep 14th, 2011, 07:48 PM
  3. Are you satisfied with the Water Magnet?
    By LS1MONSTER in forum Detailing 101
    Last Post: Sep 22nd, 2006, 07:44 PM
  4. ok, after first full detail i wasn't that satisfied
    By maxima2k2 in forum Detailing 101
    Last Post: Mar 9th, 2006, 03:55 PM
  5. Another satisfied NXT user
    By bobs409 in forum Consumer Line - Product Reviews
    Last Post: Jul 25th, 2005, 01:44 PM
