If there is anyone still looking for a way to re-attach their velcro backing pads to the 6.5" foam pads here is what I did.... I purchased some "Aleene's ORIGINAL Tacky Glue" and glued the velcro back on the foam, leaving it sit overnight with a phonebook on it. I have only used it once sice I fixed it but it has worked rather well. It seems to have bonded well and its still flexible, the glue is very thick so it did not soak into the foam. Hope this helps!
I found "Aleene's ORIGINAL Tacky Glue" at walmart in the fabric area, its in a gold bottle and sells only for a dollar or two.
