Process was #80 via PCw8006, #07via hand, #21 via hand, #26 via hand. Everything was wiped with brand new MicroFibers.
I noticed after the apply the 21, that when I wiped it off I could see dark streaks on the paint in the same circular motion as I applied it. I let the 21 set up for 30-35 minutes before wiping off. I used QD and another mf to remove the majority of these dark streaks.
Then I applied 26 by hand, let it set up for about 20 minutes then wiped away. There was minor dark streaks that I had to again QD and wipe away. When I pulled the vehicle in the sun I noticed the entier surface of the car appeared to be covered in an oily/streaky grease. Switching to another brand new mf, I wiped, but all it did was change the direction of the streaking. It would not pick it up. I used QD, to no avial.
Whats going on?
Whats going on?
