So after 2-3 frustrating tries at DACP and sympathizing with all the folks on here who say it is impossibly hard to get off.... I finally got it. You really can't say it enough, too much product and too little work time. I was probably working the DACP for about a minute which seemed like a lot and the product looked as if it was drying while I was working it. But I was totally wrong. I was very much used to working with products such as #80 and #82 that are rich in oils and easy to use and use for a while. This is much different with #83. It isn't nearly as oily and is tougher to tell when it has been fully worked.
What I really paid attention to is what 80/82 looked like when it had been worked all the way and was ready to wipe off. #83 was always much thicker hazier which caused it to be very difficult to wipe off. So with my last car I decided to work it for 2-3 minutes or more per application and boy, what a difference. I finally gave 83 a chance to polish to a shine and down to a real thin, light, completely worked, easy to remove layer. I found that 83 appears to dry quite quickly, but in actuality it is not dry, it just looks different than the other more oily products. When I continued to work the product it continued to break down and get thinner and thinner until it was cake to get off.
So my point of this post is this; make sure you work 83 into the paint until all the diminishing abrasives have broken down and all that is left is a real thin layer of polish left on the surface. If it is still devilishly hard to remove, increase your work time and sooner or later you'll get it. Now this is definitely one of my favorite products. 80/82/83 are 3 fantastic products.
A before and after from a 83/80 application.
