I might have my dad talked into buying a polisher, Its the Porter Cable 7424 Random Orbit, Variable Speed from 2500-6000 orm. (althought not throught Meguairs due to the price) but regardless I am insiting on using Meguiars pads and products. My question is will I need both the W-8006 soft polish pad and the W-9006 Finishing pad both to do a detail on a truck with swirl marks in it. I am planing on using what Mike had recomended which is M80 to remove the swirls. I assume that I will need to use the Soft Polish pad when applying the #80 then use the Finsihing pad when applying my #21 and NXT, do I remove all these products using a Ultimate Bonnet? Or do I remove the 80 by hand and the other with the bonnet? Im new to polishers and any tips, links, or other info on how to use one correctly, seepd and pressure info, so on and so forth is GREATLY appreciated. I know I have asked alot of questions but I am adimant (sp?) about doing a excellent job on any vehicle that I detail.
Also Will the Meguiars pads work without a meguiars backing plate? I would assume that as long as its a 6.5 inch velcrow backing plate it will be fine wont it? Or will we need to get the Meguiars backing plate along with the Meguiars pads?
