| How-To Articles Please don't start a new threads in this forum. If you have a question, post it in Detailing 101 - Thank you! |
#1 |
The Squeak Test - How to test for the presence of wax
This article can be found in the Meguiar's How-To Articles forum ~~~~~~~~~~~ An accurate indicator of whether there is a protective wax coating on the surface of your car's paint or not is a test Meguiar's has been teaching for probably close to 50 years if not longer. We teach this at all of our detailing classes here at Meguiar's on Saturdays' also, it's called the Squeak Test. Note: It's vitally important that you first wash your car before performing the squeak test, the paint needs to be clean and free from any dirt or dust. Wiping with a quick detailer may give you a false reading as most quick detailers add gloss and slickness, thus adulterating the test Here's how you do it, you get a clean, soft 100% cotton terry cloth towel. In this case, I'm using Meguiar's new Soft Buff™ Terry Towels polishing towel. Lay the towel out flat, then fold it in such a way as to ball it up, in my case, I fold each corner into the middle, and then repeat that a second time. This gives you a ball of terry cloth toweling that provides a flat surface against your finish, plenty of cushion between your hand and the paint, and something for your hand to grasp onto. Now, twist the towel firmly against your car's finish in a circular back and forth motion and listen... If there is silence, and the towel glides and slips on the paint, then there is wax present. If you hear a squeaking sound, (as in squeaking clean), then there is no wax present, (or very little) and it's time to apply more wax. Here's how this works, Your coating of wax acts as a dry lubricant, it creates slip and decrease friction, if there is wax present on the finish, your towel will slip instead of grab and you wont' hear any noise, in other words, you won't hear any friction. If there is no wax on the surface, then the circular twisting motion will create friction and you will hear a squeaking noise. Like Meguiar's Swipe Test, is a more accurate indicator of whether a wax has fully dried and is ready to remove, Meguiar's Squeak Test is a more accurate indicator of whether or not their is wax on the surface. By the word wax, we mean anything that is intended to protect the finish, whether it's labeled polish, or paint protectant, or sealant, or whatever... If it's a product designed to be applied to the paint to protect it, it can generically be placed into the wax category, or the 4th step of Meguiar's 5-Step Paint Care Cycle. Meguiar's 5-Step Paint Care Cycle Step 1 Wash Step 2 Clean Step 3 Polish Step 4 Protect (The wax step, anything that is intended to protect the finish, whether it's labeled polish, or paint protectant, or sealant, or whatever... ) Step 5 Maintain Hope this helps...
__________________
Mike Phillips Office: 800-869-3011 x206 Mike.Phillips@Autogeek.net "Find something you like and use it often" Last edited by Mike Phillips; Nov 23rd, 2007 at 07:28 PM.. |
#2 |
gR8 roundup as always
#3 |
Automotive Writer, Editor
Recently, I could hear light squeaking even right after the application of FK Pink Wax, Collinite 845 and Mothers FX Spray Wax...
Done with a Victoria Wax Ultra Plush MF. |
#4 |
Re: The Squeak Test - How to test for the presence of wax
I too did a full detail 4 weeks ago, used quik wax 2 weeks ago, washed it yesterday, and hear a light squeaking!
How comes? |
#5 |
aka: 23jam
I did not know threr was a scientific term for this. i always thought that if you placed a towel on your finish and it slid off you were good to go. Now I see i was performing a variation of the sqeek test. learn something new all the time. lol lol
__________________
quality creates its own demand |
#6 |
nice!
#8 |
I used the squeak test for the first time today....When are moved very slowly with a fair amount of pressure there was squeaking, when I moved a medium speed there was no squeaking. Is it time to wax again?
| Brits Crazy Car Wax Test | TimG | The Break Room | 12 | Feb 5th, 2009 09:38 AM |
| Just What Difference Does A Wax Make? - A Test To Find Out! | Kickin Griffin | Detailing 101 | 26 | Jan 4th, 2009 03:48 PM |
| Hello, test, test, initial post. | civicsam | Introduce yourself | 6 | Jul 7th, 2008 07:44 AM |
| the Squeak Test | smurf | Detailing 101 | 9 | Jun 12th, 2006 07:49 AM |
| Timed Test -- Tech Wax vs. Spray Booster | tguil | Consumer Line | 14 | Mar 4th, 2005 01:12 PM |
