Engine Detail
  • Engine Detail
    I wanted to post the fruits of my labor, this past weekend. This topic always gets mixed "How To's". But I took some tips I received here on the forums, weeded out what I thought sounds right, and tossed the rest.
    Vehicle: 2003 Dodge Ram 1500 4x4
    Approx. Time: 30 minutes
    Products Used:
    Cleaner Wax - A12
    Safe D-Greaser w/Foaming Sprayer
    Hyper Dressing
    Glad Cling-Wrap (Yes, the stuff my wife uses for leftovers)
    High Tech Applicator
    Parts Cleaning Brush
    Water (from the hose)
    Elbow Grease (Please don't ask where you can buy this at)
    Important!! I covered both sides of the fenders on my truck. Safe D-Greaser mixed 4:1 (Which I used) will remove wax if it gets on your finish.
    I started by warming the truck up a little (warm not hot to touch). I then placed the Cling wrap over the alternator, fuse box, and battery terminals. I attacked the roof under the hood first, by spraying Safe D-Greaser all over. I took a kitchen sponge (I thought my brush was to stiff too use on the paint), and began working the degreaser in. I then hosed the degreaser off. I dried off the hood with my shop vac, and some towels. I proceed to apply Cleaner Wax (A-12) under the hood with a High Tech Applicator, and left to dry.
    While the Cleaner Wax was still on under the hood, I proceeded to the engine. I sprayed the engine down (with no nozzle or sprayer just let the water pour out on very low). I followed the same step with the Safe D-Greaser, and sprayed all over. I then took my parts cleaning brush, and agitated the degreaser. I then rinsed the degreaser off. I used my Shop Vac to blow the areas out where water sat in pools. I then removed the cling wrap, and started my vehicle again for about 5 minutes. This helps the drying process. I towel dried any areas the still had water sitting (very few areas). I then applied the Hyper Dressing in the same manner all over, but avoiding spraying on the belts. I let it sit for about 10 minutes. During this time I went back to the roof under the hood, and removed the cleaner wax with a Terry towel. After that was complete, I went back to the engine. This time rubbing in the Hyper Dressing making sure it's even and not pooling up in any areas. I then closed the hood and had some lunch. When I came back to inspect my work, I was amazed
    Here are the before pics:
    Never argue with an Idiot.. They'll only drag you down to their level, then beat you with experience..
    And now the before and afters:
      One Last shot:
      Not perfect, but I was very satisfied!!
      Enjoy, Magic
        Looks great.. just another good reason to have cleaner wax laying around.
          Hey Magic
          The engine looks fantastic!! Better than when it was new!
          I hope you don't mind but I am going to move this thread into the Show Off forum where others can be inspired!
          Again, great job!
          Tim
          Tim Lingor's Product Reviews
            Thanks...
            I hadn't realized that I put it in the wrong area..
              I think my truck runs better when the engine bay is detailed!!
              http://img73.imageshack.us/img73/546...mallgz2.th.jpg
                Good job!
                I'm also looking into detailing my engine somewhere closer to summer. Good write-up.
                Though I'm a bit afraid that I'll forget to cover something up. What about I cover things up I think that should be protected from water but after I detail the engine I wait 24hrs before I start the car, will there be still a risk?
                Oh and I do feel the same way, whenever I cleaned / polished / waxed my vehicle, "she" seems to run better than before (changing oil also does wonders )
                showroomglaze.net
                  The main reason you start your vehicle up right after a detail, is to help the drying process. If you did get water where it doesn't belong, this helps evaporate the water. If water does foul something, you wouldn't want it sitting for 24hrs!!
                    Great job!! I have all the supplies to do that to my Ranger, but lack the motivation at the moment. Maybe that will change this weekend!
                    2003 Mach 1
                    Azure Blue
                    5 speed/IUP
                    2007 Tacoma DC 4x4 TRD Off-Road
                    KY Horsepower
                      WOW, what a huge difference! I am going to detail my engine this weekend
                        looks AWESOME MATE
                        NICE WORK!!!
                          Looking good. What what you use if you had some pretty heavy dirt ? From dried mud for example. Im thinking just a little more elbow grease.
                          www.dirtballsgarage.com
                            Re: Engine Detail
                            Looked at O'Reillys today and while they have a lot of Meg product along with several other brands of stuff, I didn't see any hyper dressing, A12 or Safe d greaser. In fact the engine cleaning stuff was on the other side of the store and mostly spray solvents. Since this will be my first engine and it's on an old 95 mitsubishi mirage beater that leaks oil, perfection is not the goal. What I am looking for mostly is practice and experience and I expect anything I do will be a huge improvement ,however short lived. Any suggestions on decent substitutes? I'll be looking around and/or ordering the good stuff, but I want to get this one going right away.
                              Re: Engine Detail
                              Big diffrence! Nice job.
