Follow us on: Follow Meguiars on Twitter
Customer Care Center:
800-347-5700
Go Back   Car Care Forums: Meguiar's Online > Information Station > How-To Articles
How-To Articles Please don't start a new threads in this forum. If you have a question, post it in Detailing 101 - Thank you!
Reply
Old May 28th, 2006, 05:43 PM   #1
zeefauna
Rep Power: 5 zeefauna is on a distinguished road
How-To capture swirls, scratches, etchings and other surface defects with your camera
This may sound stupid.... How do you take a picture of the swirls on a car?
I tried on my black car, and i am sure there are swirls in there, but it just won't show on the photo.
I'd like to take a before and after shoot before trying the G100A.
zeefauna is offline   Reply With Quote
Old May 28th, 2006, 05:55 PM   #2
sneek
sneek's Avatar
Rep Power: 34 sneek is on a distinguished road
take the car out into the sun and set your camera into "P" i have no clue what that is but i know if you want to capture swirls you have to put it in that mode
i have a canon S50
sneek is offline   Reply With Quote
Old May 28th, 2006, 07:19 PM   #3
Mike Phillips's Avatar
Rep Power: 550 Mike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond repute
A few tips and techniques for helping your camera to focus on the surface so you can capture the defects in the paint you're hoping to remove.
Finger Pointing Focus Technique
Besides figuring out the right camera setting for your specific camera, another quick, simple way to help your camera focus on a defect you're trying to capture with a picture is to simply place your index finger close to the defect on or hovering over the finish then carefully captures a few pictures and in most cases you'll get a couple you can use on the Internet. This works for Swirls, Scratches, Etchings, Water Spots both Type I and Type II, Stains, Oxidation, etc. Basically anything on the surface. The reason you need to give the camera something to focus on is because often times when taking shots of a large, uniform, flat surface, once any focus points are zoomed out of the picture your camera has nothing to sense and focus on.
Detailing Clay
You can also use a little piece of detailing clay because in most cases you have some detailing clay around. If the paint is clean and it should when trying to capture pictures of surface defects, then when you're done taking your pictures you should be okay to put the little piece of clay back into the large piece you took it from or just through it away. A small piece will work fine. (See picture below).
Coin
A coin can also be used if the surface is flat and horizontal like the hood. Place the coin carefully onto the paint so as not to instill a scratch. If you already have a flawless, swirl-free finish then maybe stick with the finger or clay technique. If you're getting ready to buff the car out then as long as you're careful you'll be okay; remember you're going to be buffing out the paint and likely the defect you're trying to capture with a picture.
Cobweb Swirls or Cobweb-Effect
Detailing Clay
Another way to help your camera focus on a surface defect is to place something on the surface of the paint, for example in the below picture we placed a small piece of detailing clay on the paint, then let the camera auto focus and wa-la, perfectly captured swirls, scratches and a bird dropping etching in the paint.
Random, Isolated Deeper Scratch
Scratch Removed using Ultimate Compound
An Isolated Etching
How To Remove a Bird Dropping Etching by Hand using M105 Ultra Cut Compound
__________________
Mike Phillips is offline   Reply With Quote
Old May 28th, 2006, 11:16 PM   #4
zeefauna
Yeah!!! Got it now....
Look at the SHIIIINE to that SWIIIIIRLS!!!
My fingers almost got burnt...
It's amazing how a 3 month old car got these swirls....
Old May 29th, 2006, 01:35 AM   #5
Justin Murphy
Clean4U Detailing
Justin Murphy's Avatar
Rep Power: 17 Justin Murphy has much to be proud ofJustin Murphy has much to be proud ofJustin Murphy has much to be proud ofJustin Murphy has much to be proud ofJustin Murphy has much to be proud ofJustin Murphy has much to be proud ofJustin Murphy has much to be proud ofJustin Murphy has much to be proud ofJustin Murphy has much to be proud ofJustin Murphy has much to be proud of
Quote:
Thank your dealership for washing it for you!
__________________
www.clean4udetailing.com
Justin Murphy is offline   Reply With Quote
Old May 29th, 2006, 03:19 AM   #6
zeefauna
The next time i get a new car, i will inspect the paint under the sun...
Old May 29th, 2006, 01:05 PM   #7
Wingsof66
Rep Power: 6 Wingsof66 is on a distinguished road
Quote:
Besides figuring out the right camera setting for your specific camera, I often times place my finger on the finish as though I'm pointing to the swirls, (which I am), but the main purpose of my finger is to give the camera something to focus on so the surface, (where the swirls are), is in focus.
That was one amazing tip. I've always have problems getting the camera focused on a glossy and "swirly" surface.
Great idea to give the camera something "solid" to focus on..
Thanks.
Wingsof66 is offline   Reply With Quote
Old May 29th, 2006, 01:16 PM   #8
Wingsof66
... and if the sun is not there, use a xenon light...
This is a Brinkmann Dual Xenon, portable and rechargeable.
Old May 30th, 2006, 05:11 AM   #9
zeefauna
I will be getting my DA polisher soon with some other supplies.
Will post the "after" shots... if it turns out well.
Old Jun 9th, 2006, 12:52 AM   #10
zeefauna
I was looking around for the Dual Xenon by Brinnkmann and came across this cheap xenon flashlight on eBay for $10 with shipping.
Tried it just now with these results...
You're right... it's swirl city down there...
Reply
Tags
How-To Capture Swirls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Using the G-100 to remove swirls, scratches and etchings... Mike Phillips The Dual Action Polisher 29 Oct 19th, 2009 02:56 PM
swirls and scratches Nick O Detailing 101 5 Apr 1st, 2008 02:21 AM
used #80 for light surface scratches oc detailer Detailing 101 5 Aug 24th, 2005 03:08 AM
Scratches/Swirls kvuong Detailing 101 3 Jul 18th, 2005 07:14 PM
deeper scratches and swirls Q tn350z Detailing 101 7 Dec 16th, 2004 04:13 PM
©2004 - 2009 Meguiar's Inc.
