| Detailing 101 New to detailing or just have a question? Ask here! |
#1 |
Help with debadging?
Hi, i'm new to this site but have been using meguiars porducts for a while now. I'm pretty good a detailing but i have a question about debadging my truck. I have a 2002 dodge ram 2500 (the 2nd Gen body style 94-02) I had the driver side of the truck repainted recently and the body shop left the emblems and molding off the truck for me but they didn't take off the tail gate decals. On the pasenger side they buffed the truck and you can't hardly tell any fading in the paint where the emblems were. Now I'm going to take off the decals on the tail gate myself. I know there will be some fading in the paint so is there anything i can do to make it less noticable? I keep the truck very clean. I do have access to a rotary buffer if needed.
thanks matt
__________________
2002 Dodge Ram 2500 Cummins 4x4. Red Regular cab long bed. |
#2 |
Was the tailgate repainted too?
I think you'll be fine. I have a 2001 Neon and there was no fading behind any of my badges. I took them off towards the end of 2005. |
#3 |
No the tail gate wasn't repainted, just the bedside and the side of the cab/fender. I'll give it a go and take off the emblems. thanks!
__________________
#4 |
Not related at all, but where in NW Indiana are you from?
#5 | |
Quote:
__________________
#6 |
Thin decals or thich badges?
You might try the following when debadging: Gentle heat (as in hairdryer), adhesive removers (I like the 3M stuff), waxed dental floss. I debadge many of our vehicles and those work well for me. I'd sure *NOT* use a tool other than the floss. I've done OK with plastic razor blades, but far too many people post "how do I fix this debadging boo-boo?" threads. What usually happens is the heat softens the adhesive enough to get the badge off with the floss, but leaves some adhesive behind. The adhesive remover takes care of that. Hold the adhesive remover against the surface to let it dwell/work on the glue. Don't scrub hard lest you mar the paint. I'd adjust the above for use with decals but I'd expect to have to do more work with the solvent and rely less on the heat. Fading: some fading might be under/through the clear and you'll just have to live with that. Seems to happen most with reds.
__________________
Practical Perfectionist |
| Problem after debadging my car. Missing clear coat? | T3hD0gg | Detailing 101 | 16 | Jul 17th, 2008 04:00 PM |
| Debadging help | tguil | Detailing 101 | 5 | Nov 18th, 2006 05:58 AM |
| Debadging/Messed Up | NYYankeeDodge | Detailing 101 | 29 | May 11th, 2005 07:43 AM |
