What are the advantages of one over the other? What is the difference in the two products?
Quick Detailer vs. Final Inspection
Re: Quick Detailer vs. Final Inspection
What's the difference between Quik Detailer and M34?
Originally posted by rsinor View PostWhat are the advantages of one over the other? What is the difference in the two products?
Both products are mist and wipe products, the primary difference is that Final Inspection is formulated to be used in a body shop environment where fresh paint is being sprayed, Final Inspection is Body Shop Safe. This means there are no ingredients in Final Inspection that will interfere with paint adhesion when painting a car.
If you work as a painter in a body shop then you should be using Final Inspection, if you don't, i.e. if you're an enthusiast detailer or even a Pro detailer, then it doesn't matter what kind of mist and wipe product you're using because you're not spraying fresh paint in a body shop environement.
Both products work awesome, pick one you like or is available to you and go with it.
Mike,
Thanks, I'm new to the forum but a Meguair's product user for years, I like final inspection have used it for years, also have used most of the other commercial side products, 2, 3, 6, 7, 9, etc. I posted the question the other day about lacquer and a G100 just bought it cant wait to get started, I used to own a automotive parts businees and sold to body shops. I've seen the quik detailer I never used it but at shows I see a lot of guys using it rather than the final inspection. So I was curious if there was an advantage to it over final inspection. Still have at least a gallon of final inspection on the shelf so it will be a while before I consider the change just curious.
Thanks, I'm new to the forum but a Meguair's product user for years, I like final inspection have used it for years, also have used most of the other commercial side products, 2, 3, 6, 7, 9, etc. I posted the question the other day about lacquer and a G100 just bought it cant wait to get started, I used to own a automotive parts businees and sold to body shops. I've seen the quik detailer I never used it but at shows I see a lot of guys using it rather than the final inspection. So I was curious if there was an advantage to it over final inspection. Still have at least a gallon of final inspection on the shelf so it will be a while before I consider the change just curious.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Originally posted by gb387 View PostMy .02... I think you see 'Quik Detailer' more as you can just run to Walmart/Target and pick it up, very easy to find without a thought. Final Inspection you may have to get it online, from Meguiars.com or from a local parts store, still easy to find but not as easy. Other than than its more personal preference when talking Meguiars Detailers. Now I like Last Touch, yet another detailer!
mike can you just answer that, because if there isn't much difference, i'll just stick with the QD (i was planning on getting some last touch since people give it great reviews, just to try out)
thanksIvan Rajic - LUSTR Auto Detail
Chicago, Illinois
Recognized as One of the Top Nine Auto Detailers in the US by AutoWeek Magazine!!
lecchilo: they all work the same. Last touch doesn't seem to work better than QD. I use Last Touch because it comes in 4 L bottles instead of the small sprayers like QD. (and in the end it's cheaper because of the dilution)
Last touch contains (I believe) very small amounts of silicone, which is a big no in body shop / paint shop environments. So like Mike said, M34 if you work in fresh paint environments (or on fresh paint) and all the others (QD, speed detailer, Last touch) if you're just detailing around.
Some of my fellow detailers however always use M34 because owners sometimes forget to mention they had their car repainted so to be sure, they always use M34. I use a checklist whenever a vehicle checks in and fresh paint (Y/n) is one of the questions, based on that information I use m34 or Last Touch.
Originally posted by lecchilo View Postis last touch the same as final inspection in that it's intended for body shops?
Originally posted by lecchilo View Postmike can you just answer that, because if there isn't much difference, i'll just stick with the QD (i was planning on getting some last touch since people give it great reviews, just to try out)
thanks
Originally posted by Mike Phillips View PostLast Touch is a slicker, higher gloss detailer than our other mist and wipe products, it can also be diluted 1:1 with water when using it as a clay lube.
Originally posted by Mike Phillips View Postif you're an enthusiast detailer or even a Pro detailer, then it doesn't matter what kind of mist and wipe product you're using because you're not spraying fresh paint in a body shop environement.
