Update from this:
Sorry, no pictures yet. I'll try to capture what I'm trying to fix on the paint tonight and update this post.
Car - 1981 Supercharged Porsche 928
Color - Single stage Mocha Brown (I have reason to believe at least three panels are not original)
I'm not sure how to describe this. A couple of panels have spots that look like hard water stains. I have my doubts about them being water marks since I've caused hard water stains in the past and I've been able to remove them. These never change.
The panels with the spots are also the same ones I think have been repainted (or the rest of the car was sprayed & these are original).
The spotted panels also have the worst oxidation when I pull it out of winter storage every spring. Using the consumer 1-2-3 line by hand I've always been able to shine up the paint. Usually mid summer I have to hit it again since the brown starts to fade.
Using my new products I started with a two bucket wash & dry. The car sat in my garage for about a week until last night when I could start cleaning the paint.
So far I've only worked on the top side of one fender.
Much to my suprise, the medium clay bar didn't seam to remove much. I was using a 50/50 mix of Last Touch. Unless somehow I was doing this wrong. The paint on this car feels very smooth already so...
I started with Deep Crystal paint cleaner, didn't really do anything.
Moving down the line I tried #82, started to see some results so I jumped right into #83. Whoa - spots are now gone!!! Except one problem, really bad hazing. I turned up the speed on the D/A, tried again. The hazing got better but still there.
So I thought "what the hell" and moved to #80. This took out most of the hazing, I was able to clean it up with another go with #82.
Next an application of #7, followed by an application of NXT wax (non 2.0).
Looks 100x's better than the hood. There are still a lot of small stone chips that are not all the way through the paint (yet). Not sure if the D/A will be able to fix these, but with the spots gone & most of the swirls cleaned up I say this is a success!!
