Products to have?
  • Products to have?
    Looking for a quick guide of what I should have in products with the g110.
    I have #9. Should I have some #83 or #80 on hand? or are they close to the same product? if they are close to the same product, of the three what should I have more of?
    After I use #9, #83 or #80 whats next? a polish like #7? or something else? Or do I go right to wax like NXT or #26?
    I have read all the sticky's and product guides just wanted to see what you as the user are using for your/detail cars.
    Thanks
    -- www.fquick.com/TRIPOWER --
    Re: Products to have?
    Well i use a rotary for almost everything but I have used a DA and i know #80 is a good all around product to have in your arsenal of products. For a DA i would suggest investing in some good pads (W8006, W9006) and some #83 and #80, #83 being the more agressive product.. #82 is not a bad product either but it is very similar to #9.
    Jon's Premium Auto Detailing
    210-281-8151
      This thread shows some of the staples for using with any DA Polisher
      Here's a list of things we would take to a customer's location to buff out the paint...
      DA Polisher
      Lots of W-8006 polishing pads
      1-2 W-9006 finishing pads
      1 W-7006 cutting pads and a couple of microfiber bonnets for this pad
      Clay
      M83
      M80
      ColorX or M66
      M09 or M82
      Blue Painter's Tape
      A wax you like, we use NXT on everything
      Glass Cleaner
      Trim Detailer
      Plenty of microfiber polishing cloths
      ScratchX
      Terry cloth towels
      Hand Applicator wax pads
      Terry cloth we can cut into little pieces
      Scissors
      Beach Towel
      Aluminum foil
      2 Mil Drop cloth
      Clean flat, bed sheet for covering things like the engine up if needed
      Toothbrush or other nylon brush for cleaning pads and getting wax out of the cracks
      Tire Dressing
      That's off the top of our head.... should be able to tackle just about anything that doesn't require a rotary buffer but we also take one of those.
        DA Polisher
        Clay
        M83
        M80
        ColorX or M66
        M09 or M82
        Blue Painter's Tape
        Glass Cleaner
        Trim Detailer
        ScratchX
        Terry cloth towels
        Scissors
        Beach Towel
        Aluminum foil
        2 Mil Drop cloth
        Tire Dressing
        I understand all but the beach towel. Mike - please explain.
          Sometimes it's good to have beach towels to cover the engine bay area under the hood, or covering the windshield when working with a rotary to know if there is splatter you don't get product in the window or the wiper arms and to on
            DA Polisher
            Clay
            M83
            M80
            ColorX or M66
            M09 or M82
            Blue Painter's Tape
            Glass Cleaner
            Trim Detailer
            ScratchX
            Terry cloth towels
            Scissors
            Beach Towel
            Aluminum foil
            2 Mil Drop cloth
            Tire Dressing
            That's what i was looking for!
              yalerd nailed it.
              Lots of cars have either a grill around the wiper arms that you don't want to get splatter into because it's impossible to get to in order to remove, (not that we would ever splatter our product ), and/or pebble textured plastic between the hood and the window glass.
              Most beach towels are fairly long and thus long enough to drape over the entire width of the car to cover the wipers, plastic, grill, etc and then carefully fold under the hood.
              Always be careful and check that the towel isn't going to bind with the hood hinges or anything else before closing the hood.
              This enables you to cover these areas win one fell swoop and move on to the job at hand.
              There should be a picture of this on the forum somewhere but not sure how to search for it.
                Yup, just be sure it’s a clean one, not one that just came back from a day of lying in the sand (that’s a real problem here in OC).
                Flannel sheets also work great.
                PC.
                  Ahh, good idea. I'll add one to my ever expanding detail kit.
