Go Back   Car Care Forums: Meguiar's Online > Detailing - Everything from A to Z > Detailing 101
Detailing 101 New to detailing or just have a question? Ask here!
Reply
Old May 6th, 2008, 03:54 PM   #1
EV0B0Y691
Rep Power: 4 EV0B0Y691 is on a distinguished road
Need Quick Replies! Oxidation Help!
I am going to be detailing a catering van soon, the owner told me to take a look at it today and the paint was oxidized. The paint is still white just oxidized as in faded, it's not warped or anything. Is there anyway I can restore the gloss and smoothness of the paint without a PC? I'm looking into rubbing compound or the new Mother's Powerball4Paint with Scratch X.
Any other tips or recommendations? He is looking into repainting it..i don't want him to waste his money
EV0B0Y691 is offline   Reply With Quote
Old May 6th, 2008, 04:08 PM   #2
Derrick
Derrick's Avatar
Rep Power: 30 Derrick has a spectacular aura aboutDerrick has a spectacular aura aboutDerrick has a spectacular aura about
Re: Need Quick Replies! Oxidation Help!
With out a pc or rotary it will be a hard and long process but it can be done. I would suggest investing in a cheap orbital buffer if you dont want to invest in a DA. You can get one from a local autozone or auto parts store for around 30 and they usually come with wool bonnet and a foam bonnet if not get both of those. First wash and clay the car then you can move onto your ScratchX and use the wool bonnet for this. You will need to use a little pressure probably about 15-20lbs or so. Then after that you may need to go over it a few times to really get it off then you might have to hit it one last time with the foam pad to remove any light marks the wool pad has left behind. Then after that you can go ahead and apply a pure polish like #7 or DC2 by hand and finalize with the wax of your preference and that should get you decent results. I have done that method along time ago before i got into rotary and it worked out pretty good for me. Now it wont be perfect but its about the best suggestion i can give you besides using a pc or doing it by hand wich will take forever. Hope that helps
__________________
Jon's Premium Auto Detailing
210-281-8151
Derrick is offline   Reply With Quote
Old May 6th, 2008, 04:23 PM   #3
Mike Phillips's Avatar
Rep Power: 875 Mike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond repute
What year is this Van?
Most people confuse oxidatoin with clearcoat failure, if the van has clear coat failure then there's nothing you can do.
If it is truy oxidatoin than any of our cleaner/waxes will fix the problem.
Look at the pictures in this thread and see if the van looks like any of these,
The Clearcoat Failure Archive
This is oxidaton
It can be fixed
__________________
Mike Phillips is offline   Reply With Quote
Old May 6th, 2008, 04:39 PM   #4
EV0B0Y691
It's an old catering van....90's i think. It's been oxidized since....'99 or so. Thanks for the tips! So attack it with ScratchX? Rubbing compound won't help?
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
quick detailer vs quick wax alexplantman Consumer Line 5 Aug 7th, 2008 10:15 AM
Quick Detailer, Quick Wax, Final Inspection??? Nick Chapman Detailing 101 4 Oct 1st, 2006 10:30 AM
quick detailer and quick wax. demonicus666 Detailing 101 3 Jul 11th, 2006 01:39 AM
Idea Quick Wax on Quick Detailer Jbirk Detailing 101 12 Sep 7th, 2005 09:51 PM
How quick is quick using NXT Spray Wax S60slipstream Consumer Line 3 Dec 9th, 2004 05:51 PM
©2004 - 2009 Meguiar's Inc.
