1998 Honda Accord Headlight Resto
  • 1998 Honda Accord Headlight Resto
    Well, I came across some gift cards today with $40 on each and decided "why not go get some PlastX and some other toys" Get to Kragen, they have a coupon for the new Meguiars Headlight Restoration Kit for $19.99, I got the last one. Came home and got right to work. This is after 2 passes using the supplied drill pad. The lights have heavy chips on them from hard abuse.
    Should I wetsand to get a better result and/or smoother surface then reapply PlastX?
    Currently has 200,000 miles on it.
    AND yes i know my tape job is really bad
    TOOLS USED:
    Black and Decker corded drill
    BEFORE
    AFTER
    Re: 1998 Honda Accord Headlight Resto
    Looks good there Dino!
    Ryan
      They look really good
        Huge improvement. They look really good here.
          Very nice job, big improvement!!
            Looks good, you could try a small area with wet sanding and see if the results are worth it to you. I can't remember if that kit comes with sand paper.
            Schotography
              I used 3000 on my lights and they didn't improved that much. So I would say you did a good enough job and you really can't improve much. But you can try.
