Here's one for the record books. This thing was in horrible condition! Guy showed this truck, and I'm baffled how he even brought it out of the garage much less a car show.
Black Colorado...
Re: Black Colorado...
This one was a very strange cookie. No matter what, I could not finish it out correctly. I tried everything in the books to get it to finish out, but nothing worked. I even went through Menzerna and 3M products, nothing worked in the traditional methods of rotary or DA. After about 6 hours of going through everything I had, I stuck a yellow foam pad on a DA with some M205, and presto!!!! This is the end result. The biggest factor in finishing this out was a firm pad and VERY little product. I had to clean the pad after every 2nd pass, and apply 2 drops of M205 to the pad, then work it in over a 2x2 area. Work another 2x2 spot, then blow the pad out again, and continue this throughout the entire truck.
So if you're having a problem with "tick" marks or buffer swirls while using M205, try to reduce the amount of product, and work it in with a firm foam pad on a DA, and clean the pad OFTEN! This method produced rotary results on this truck.
2008 Meguiar's Batmobile Team
2008 Meguiar's/Ford SEMA Team
2009 Meguiar's/Ford SEMA Team
2010 Meguiar's/Ford SEMA Team
Nice work Nick, good job testing and testing until you found a combination of pad, product and technique that worked.
Hope you set this guy up on a regular maintenance program where you do the washing and waxing...
I hope you clued him into how to how his finish became so swirled out to start with?
Originally posted by Mike Phillips View PostNice work Nick, good job testing and testing until you found a combination of pad, product and technique that worked.
Thats one thing I do with all of my customers. I teach them how to properly wash their vehicle, give them a list of products to buy, and give them Rick's # over at ADS2008 Meguiar's Batmobile Team
Originally posted by sudsbyhubbs View PostThe truck looks amazing! Thanks for the tips on #205 as well.2008 Meguiar's Batmobile Team
What a transformation! Beautiful job.
You cleaned the pad after every second pass and you say you [blew] it out. Do you mean with compressed air? Also, did you use the same polishing pad for the entire vehicle?2013 Highlander - black
2010 TL - black
This is a great example of the fact that there is not just one solution to buffing out a car. A key point is working a test spot until you find the combination that works, and don't be affraid to experiment.
Great work Nick-Bob
Originally posted by gjohn28 View PostWhat a transformation! Beautiful job.
You cleaned the pad after every second pass and you say you [blew] it out. Do you mean with compressed air? Also, did you use the same polishing pad for the entire vehicle?2008 Meguiar's Batmobile Team
