Car Damage - Plan of attack!
Re: Car Damage - Plan of attack!
What kind of car is it? at first glance it looks to be a Scion tC. If toyota paint is any like honda's than some aggressive cutting polish and a D/A should at least help that.
Just from my pretty limited experience I would probably start with some M105 on my D/A and take it from there. With all of the ridges that the front of the car has I'm sure you went all the through the paint in some spots especially around the wheel. It doesn't hurt to try though, I'm really curious to see the results of whatever you attempt though.
My plan of attack would be something like M105 followed by M205, just have to take it one application at a time and see if your getting acceptable or even any results.
Seems like you have paint transfer, so you can remove that and maybe you'll be leaving behind some deep scratches that you'll just have to live with it of repaint.
Try this:
-Wash
-Clay
-ScratchX 2.0 with a terry cloth towel and follow this with a foam pad applicator
-Wax
Here are a couple of links that could help out with the techniques:
Originally posted by yalerd View PostSeems like you have paint transfer, so you can remove that and maybe you'll be leaving behind some deep scratches that you'll just have to live with it of repaint.
Try this:
-Wash
-Clay
-Wax
It looks like the edge of the wheel well took a shot, so that might be scratched pretty good. You can't really mess up anything since a repaint is needed to totally correct the problem, so give it a go by hand (as mentioned above) and see what you can do.
I had a similar incident with my Volvo and it cleaned up pretty well, although my car was a lighter paint color so it helped minimize the scratches. Let us know how it turns out and good luck!NOTE: Post count does not reflect actual detailing knowledge.
The white paint that transferred onto you blue paint can be removed using Ultimate Compound by hand, you might have to start with some terry cloth as the nap of the terry cloth will provide some extra scrubbing power and then do a final pass with a foam applicator.
After that be sure to apply some wax as the compound provides no protection.
Here's some threads on this topic,
Update on this... I'm not sure what the white is because the car that caught mine was red. If you look close at the big white spot you can see a hint of red in it. I already ordered a bottle of factory paint so i think i will try and buff out the inperfections real well, use some scratch X to clean up the fine scratches, use the touch up paint, and then use a product to help smooth out the touch up paint. After this I will wax and polish...
any thoughts on this?
Thanks for everyones input already! Great site!
Besides the dents, the other problems are what we call Paint Transfer
Click the link below and read through the threads listed as this is a fairly common problem and there's some meaty stuff already posted on this topic and they are tagged with the tag Paint Transfer.
http://meguiarsonline.com/forums/tag...Paint-Transfer
It looks like a Scion tC or a BMW.
I am not sure, I can not see the front of the headlight. (I am really good at identifying cars by headlights and taillights)Joel
Try this:
-Wash
-Clay
-Wax
What it means to remove a scratch out of anything...Art Layton
2009 Jetta TDI
Haha... yes it is a Scion TC.... I've had it almost 3 years and only issue was a minor door ding... and then this big one! :-( The paint on this car has held up really well though. Once a year I do a full detail and it looks brand new when im done with it.
I'm going to try and tackle the repair tomorrow and will post some updated photos.
UPDATE!!! - Car Damage - Plan of attack!
Here are some updated photos.... I'm very happy with how it turned out.
Steps
Wash
Clay Kit
Scratch X2
Cleaner Wax
and yes by popular request i cleaned up wheels while I was at it! ;-)
I still have to get the touch up paint and do that process. Thanks for everyones great input!
BEFORE:
AFTER:
