| How-To Articles Please don't start a new threads in this forum. If you have a question, post it in Detailing 101 - Thank you! |
#1 |
Dino
How To Remove Water Spots off Glass using M04 with an RB
Here's part of my first major detail. I'll add steps and pictures to this thread once I get around to it in no particular order. First up... Window Correction:
Figure 1: Tools and Products. ![]() Figures 2 and 3: Before shots of waterspots. ![]() ![]() Figures 4-6: 50/50 shots ![]() ![]() ![]() Figures 7-9: Final shots and reflection. ![]() ![]() ![]() |
#2 |
Learning True Art of Detailing
Re: 2003 Chevrolet Avalanche
That looks absolutely great. Good job.
__________________
Learning new things everyday |
#3 |
Fire Dept. Detailer
Looks Great!!!
Huge Improvement!! Nice Work!! Now they can see out of the GLASS!!
__________________
Joel Rejuvenation Auto Detailing "Satisfaction Guaranteed or Your Dirt Back!!!" '99 F-150 '02 Town and Country |
#4 |
nice work, that looks brilliant.
#5 |
Excellent write-up and you show really horrible water spots and how M04 ws able to remove them without scratching the glass. Anyone reading this note that mr.haributo used blue painter's tape to tape off all the edges surrounding the glass. If you don't do this you will get M04 Heavy Cut Cleaner splatter residue onto the rubber, plastic and felt trim surrounding the glass and into the cracks and crevices in these areas and this residue will be messy and difficult to completely remove. It's so worth the extra time and expense to thoroughly tape off around the glass before machine buffing the glass. It's even a good idea to do this if you're working by hand because chances are good you'll still get residue onto the rubber gaskets surrounding the glass and taping off saves you from having to come back and clean these ares.
Good job! The water spots on the glass in these pictures looks a lot like the water spots on many of my customer's cars when I lived in Oregon and you can't polish out the paint on a customer's car and leave the windows covered in water spots, it doesn't look good and takes away from the "wow" factor you want your customer to experience when you return their car back to them after the job is finished. Also just to note, if the glass has water spots like this then chances are very good the paint has the same kind of water spotting too... We're going to modify the title to this thread and place it in the How To Articles forum as a guide for others to follow should they have water spots this bad on the paint. Just to note, the M04 can also be used by hand to do the same thing but it will take longer and you'll have to put a little passion behind your applicator pad. The DA Polisher can be used but in most cases to remove water spots this bad on glass you'll end up trying to apply so much pressure to the had of the polisher that your pad will tend to stop rotating and thus it's not as effective as working by hand or with a rotary buffer. ![]()
__________________
#6 |
Re: How To Remove Water Spots off Glass using M04 with an RB
Very nice, but is there anyway that this can be done by hand?
#7 |
read Mikes post.
#8 |
Dino
It's possible to do by hand. That's how I got the edges and corners of the windows. I applied a small pea sized amount on a Costco mf and buffed away. The rotary helps the overall process.
#9 |
Self-Banned
Wow this is cool..I needed this. Thanks for input.
#10 |
The Great
Great job on the windows bro!
__________________
Take risks and make mistakes, that's living the real life. |
| Question on using M04 on glass/windows… | Chesney09 | Detailing 101 | 19 | Mar 15th, 2009 04:47 AM |
| water spots on glass | miahjohn | Detailing 101 | 13 | Jan 13th, 2009 06:31 AM |
| how to remove scratches & water spots from glass? | silvSS03 | Detailing 101 | 5 | Apr 9th, 2008 05:30 AM |
| Water Spots On Glass | 29bowtie | Professional Line | 17 | Mar 24th, 2008 02:02 AM |
| M85 - Can Be used To Remove Water Spots From Glass? | poyo | Professional Line | 16 | Jan 30th, 2007 03:35 AM |
