I do a lot of paint and bodywork, which means I do a lot of sanding and buffing. I use pretty much all Meguiars pads, however I do use a Chicago Pneumatic 7201P Mini Air Polisher Kit - 3" with 3M pads in tight spots and around edges..
My issue is that any place I use this polisher, it requires a pretty large air compressor, so this can be an issue from time to time. Many things that I paint will end up back at someone's garage that doesn't have a large compressor so I'm looking at the 4" CCS pads for my rotary and G110
My question is how do these pads compare to meguiars. Does Lake Country cutting pad equal the W7207? More cut or Less Cut?
Does the Lake polishing pad equal the meg polishing pad? More aggressive??
I see they make about seven different 4" pads, I tried to find a comparison on cutting ability or aggressiveness without much luck so any input from you guys would be apperciated...
I would like to stay with a three pad system if I can. Cut, Polish, and Finish but I'll would love to hear everyones recommendations
sorry to Meguairs to have to ask about different products on their forum but I'm in a tight spot...
I love your pads and products... just need some smaller ones
