| The Dual Action Polisher Questions on how to use Meguiar's G110, G220, G-100 Dual Action Polishers, (the PC), to clean, polish and protect paint. Also questions about product and pad selection as well as pad cleaning and maintenance |
#1 |
how to apply pure polish(m07) with DA
is there a certain amount of time it takes to work it in?
how much pressure speed at 2-3? but then not much presssure can be applied! I guess, just when do you know when you can move on to the next section
__________________
______________________ Tyler 2002 Yellow Chevy Monte Carlo SS My Albums: http://s394.photobucket.com/albums/pp24/Johnson0667/ |
#2 |
Re: how to apply pure polish(m07) with DA
There are many threads on this subject. Basically you should rub it "into" the paint, let it get a skim coat (not completely dry) and then wipe it off. I don't apply it with a DA as it goes on just as fast by hand. You are just quickly applying it to the paint and then removing it.
If I were to use a DA I'd use set it at 3 and just press lightly... about 5lbs of pressure. No need to knock yourself out. From Mike *******: "M07 is a non-abrasive pure polish, it has the richest concentrations of Meguiar's Trade Secret Polishing oils and has been around since probably the 1920's and it works just as good today as it did when the Model T was coming off the assembly line. Both products are applied to a section at a time, worked over the finish gently but thoroughly and then immediately wiped off. After you go around the car with one of the above, (there's no real need to do both), you would then apply your choice of wax or a paint sealant. Waxes and paint sealants need to fully dry before removing." and "Apply to clean paint using a clean, soft dry applicator pad. Most people work section by section or panel by panel and then remove before moving on and applying to the rest of the car. Working Section by Section would be applying to a quarter of a car hood and then removing the excess and moving on to the next section on the hood. Working Panel by Panel would be applying to the entire front passenger's side fender and then removing the excess before moving onto another panel." and everything you ever wanted to know about M07; http://www.autopia.org/forum/detaili...-phillips.html |
#3 |
Pray for our country
I've never been able to apply polish with a DA without the product gumming up on the finish.
I recommend applying #7, and any other of Meguiar's polishes, by hand only. The Hi-Tech applicator sponge pad works well for this.
__________________
r. b. "In a time of universal deceit telling the truth is a revolutionary act." - George Orwell |
| How to apply properly apply compound? | sunfire | Detailing 101 | 7 | Nov 21st, 2008 08:14 AM |
| Using Meguiar's Even Coat Applicator to apply NXT Spray Wax | Mike Phillips | How-To Articles | 12 | Aug 19th, 2006 12:18 PM |
| I need help | blackXterra | Detailing 101 | 2 | Jan 29th, 2006 03:50 AM |
| New here, have a question | ninous26 | Detailing 101 | 4 | Dec 30th, 2005 01:44 PM |
| Can NO one answer this Question ???? | x02gt | Detailing 101 | 7 | Jul 9th, 2005 05:26 PM |
