Go Back   Car Care Forums: Meguiar's Online > Detailing - Everything from A to Z > Detailing 101
Detailing 101 New to detailing or just have a question? Ask here!
Reply
Old Oct 22nd, 2009, 01:15 PM   #1
Administrator
Michael Stoops's Avatar
Rep Power: 4520 Michael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond reputeMichael Stoops has a reputation beyond repute
Let's talk about "Total Cut"
There is a lot of discussion about how aggressive one product is compared to another, often between products that aren't even designed to do quite the same task. Many of you have seen the cut scale shown on the side of most Mirror Glaze products but you may not be clear on just what they mean.
On the bottle of M105 Ultra Cut Compound you can see that the arrow goes all the way to the top - that's a 12 on the cut scale. But the M205 Ultra Finishing Polish and M80 Speed Glaze only register a 4 on the scale. Obviously then, M105 provides more cut than either M205 or M80.
But what does that "12" or "4", or any other number, really mean? Will they always provide that much cut? Isn't a "12" way too much cut when all I want to do is remove some light swirls? Should I use maybe something that registers an "8" or "6" instead?
You may have noticed that we do not provide a cut scale on our consumer products, and that is simply because there are just too many variables when dealing with the average consumer. And variables are what this article is all about.
* NOTE: the above scale is not intended to be a precise quantitative indicator of changes in cut but rather simply of visual indicator that a change in cut exists. How much more or less cut any given product can achieve is dictated by a very wide range of variables.
Looking at the chart shown above, we see that the "Total Cut" is greater when a product is applied by rotary buffer than it is when applied by hand, and that G110 (D/A polisher) "Total Cut" is somewhere in between the two. You can also see that, for example, M105 always has more cut than M205 when used the same way. Not surprising since, as has been pointed out, M105 is a "12" while M205 is a "4". But even that doesn't tell the whole story.
The key here is that phrase "when used the same way". Let's just look at polishing with a G110 using M205, but with two different processes.
Here you can see that Process 1 pairs M205 with the less aggressive pad, it's run at a less aggressive speed, and less aggressive pressure is being used than with Process 2. The net result is that Process 1 will provide less cut overall than Process 2, even though the same M205 is being used. It is the combination of variables that determines "Total Cut".
Some of the variables can have a sizable impact on total cut. When working with a rotary buffer if you move from a W8207 Soft Buff 2.0 Polishing Pad to a W5000 Double Side Wool pad, without changing machine speed or liquid, you will get a a huge jump up in total cut. The ONLY thing you changed is the pad. Or keep the liquid, the pad and the pressure the same, but change the speed of the rotary from 900 rpm to 1800 rpm and you'll get a sizable jump in total cut too. And all you did was run the machine at a higher speed. The G110 will return a similar change in total cut when doing the same experiment - same liquid, same pad, different speed - but the total cut will still be lower than that of the rotary buffer. That's because the machine has become a variable too, and a sizable one at that.
How extremely can you alter total cut when taking many variables into account? Try using M105 (cut rating of 12, remember) on a G110/W9207 Soft Buff 2.0 Finishing Pad/Speed 3/5lbs pressure and compare the total cut to M80 (cut rating of just 4) on a rotary/W5000 Double Sided Wool Pad/1800 rpm/5lbs pressure. Total cut on the M80 under these circumstances will be greater than the M105 combination cited above. (NOTE: you would probably never run M80 in this configuration - in fact, it isn't officially recommended by Meguiar's and is described here for illustration purposes ONLY)
At the risk of making this even more complicated, let's take a quick look at pad size when machine polishing. The increasing popularity of 4" foam pads has brought about a major variable. Sure, they make it easy to machine polish in smaller, tighter areas but they also alter the total cut. On a rotary buffer a smaller pad actually provides less cut (assuming similar foam construction, speed and pressure) because the speed at the outer diameter is lower than with a larger pad. We've already established that with a rotary buffer more speed equals more cut, so this slower speed at the outer edge of the pad falls right into that equation. On a D/A polisher the opposite effect results - a smaller pad gives more cut (again assuming similar foam construction, speed and pressure) because the energy is concentrated in a smaller area. The prevailing notion that you can not burn through or otherwise damage your paint when using a D/A needs to be reconsidered when using small pads. We've seen people damage paint while using a 4" cutting pad on a D/A running at maximum speed with a strong compound. When you compare that combination to a standard 6" or 7" pad with a mild paint cleaner used on speed 5, the increase in total cut is quite dramatic. It wasn't very long ago that this combination of small pad/high speed/aggressive compound was quite rare, but it's becoming more and more common place. And if you aren't thinking about how your changes effect total cut, you could be in for a surprise.
Probably nowhere is the concept of variables dictating total cut more fully experienced than when using M86 So1o Cut & Polish Cream. M86 was developed specifically for use on fresh paint, primarily in a body shop environment, and is truly part of a "system". The system is comprised of a single liquid and four different pads; a heavy wool cutting pad, light wool cutting pad, foam polishing pad and foam finishing pad. The idea is to use the liquid with one of the wool cutting pads to eliminate sanding marks, an initial cutting step done at fairly high speed - something on the order of 1500 to 1800 rpm. You would then follow with the foam finishing pad to remove any holograms or light marring, and then finish off with the foam finishing pad at a speed as low as perhaps 900 rpm to obtain a flawless finish. The very same liquid used to pull out sanding marks will also provide a flawless, highly reflective finish? Because of the variables involved and their impact on total cut, yes.
So next time your goal is to remove defects from the paint, consider not only which paint cleaner or compound you'll be using, but how you'll be using it. You choice of machine, speed, pad construction, pad size and pressure will all impact how much cut you'll get out of the liquid.
One last thought - just because a certain combination of the above variables worked on your friend's or neighbor's car does not guarantee the same result on your car because, you guessed it, the paint itself is a variable! And you wonder why this is often referred to as "the art of paint polishing"!
__________________
Internet Technical Specialist
(800) 854-8073 xt 175
mstoops@meguiars.com
Michael Stoops is offline   Reply With Quote
Old Oct 22nd, 2009, 02:20 PM   #2
TH0001
TH0001's Avatar
Rep Power: 655 TH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond reputeTH0001 has a reputation beyond repute
Re: Let's talk about "Total Cut"
Absolutely TOP NOTCH article Michael... VERY NICE! Thank you for putting this together for us!!!
__________________
Todd Helme's Bella Macchina
The ART of DETAILING
Proper Auto Care Consultant
TH0001 is offline   Reply With Quote
Old Oct 22nd, 2009, 03:22 PM   #3
ClearlyCoated
Swirls+Surly=Swurly
ClearlyCoated's Avatar
Rep Power: 497 ClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond reputeClearlyCoated has a reputation beyond repute
Another well thought-out, well written MOL thread for my saved links folder!
Thanks Mike!
ClearlyCoated is offline   Reply With Quote
Old Oct 22nd, 2009, 03:38 PM   #4
Dan Fisher
Rep Power: 2 Dan Fisher is on a distinguished road
I Would not want to be the one to make that mistake with the small pads, high speed, heavy pressure!!! Outstanding article Mike, as already said one to keep for future referral !!!!!!
Dan Fisher is offline   Reply With Quote
Old Oct 22nd, 2009, 03:54 PM   #5
Hemin8r
ShineTech Auto Detail
Hemin8r's Avatar
Rep Power: 738 Hemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond reputeHemin8r has a reputation beyond repute
Great job putting this together Mike. This here really does give a good idea of how many variables there are.
__________________
Jesse
Hemin8r is offline   Reply With Quote
Old Oct 22nd, 2009, 04:15 PM   #6
Bunky
大家好 Late Bloomer
Bunky's Avatar
Rep Power: 7 Bunky is on a distinguished road
Great chart !!!!!
__________________
Al
Bunky is offline   Reply With Quote
Old Oct 22nd, 2009, 04:50 PM   #7
Mikejl
Car Guy In Training
Mikejl's Avatar
Rep Power: 63 Mikejl is a glorious beacon of lightMikejl is a glorious beacon of lightMikejl is a glorious beacon of lightMikejl is a glorious beacon of lightMikejl is a glorious beacon of light
Mike,
Excellent chart! Very clear and nicely put together.
Mike
__________________
George Carlin
Mikejl is offline   Reply With Quote
Old Oct 26th, 2009, 09:55 AM   #8
73corvette
73corvette's Avatar
Rep Power: 2 73corvette is on a distinguished road
Michael,
I'm a consumer not a detailer, but I'll tell you in doing mt vette I am learning a lot why the good detailers get the big bucks and I am also gaining a lot of experience by doing this myself, who said you can't teach an old dog new tricks,lol. I would have never tried this if it weren't for this forum and all the knowledge and help that I've received from all the guys on this forum and I thank all you very much for the for the kind reception that I received here.
You guys are the BEST!
Rich
73corvette is offline   Reply With Quote
Old Oct 26th, 2009, 11:33 PM   #9
irf@n
Skoda Club
irf@n's Avatar
Rep Power: 5 irf@n is on a distinguished road
Great guide!
__________________
Skoda Roomster
irf@n is offline   Reply With Quote
Old Oct 27th, 2009, 02:31 AM   #10
Mark Kleis
Moderator
Mark Kleis's Avatar
Rep Power: 377 Mark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond reputeMark Kleis has a reputation beyond repute
I'm really surprised this hasn't gotten more replies...
This took a tremendous amount of meticulous research and work, and more importantly, it points out some very key concepts to paint correction that are often misunderstood, or missed completely by amateurs just getting started.
This is the type of guide that is worth getting printed out at Kinkos, laminated, and stuck in your detailing bag to stay with you where ever you go to detail.
Well done Mr. Stoops!
__________________
I'm here to help: keep MOL family friendly, keep everything running smoothly, keep the forum organized, and above all...to keep everyone happy. PM or e-mail me should you feel there is something I can do to help deliver any of those things. -Mark Kleis, Lumadar@gmail.com Follow me at www.MarkKleis.com or my automotive journalism at LeftLaneNews.com
My ride: 2006 Ford Focus ZX3, 5 Speed, Bright Red, Roush+SVT exterior conversion, Saleen suspension/lowering kit, OZ Racing 17s, Kumho Ecsta MX tires, Borla SS Exhaust, Custom Intake, Custom fiberglass doors, Suede Interior, Color Matched Red Ford ovals, Jl 1000/1, JL 450/4, (2) DIYMA 12s, Dayton/SEAS speakers/tweeters, Alpine IVA-W200 LCD, Alpine PXA-H701, Alpine TUA-T500HD
Mark Kleis is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Man, talk about some soft paint! Nick Chapman The Break Room 21 Apr 24th, 2009 10:42 AM
Lets talk pneumatic wet sanding... Nick Chapman Wet-Sanding, Color Sanding, Rock Chip Repair 7 Jan 21st, 2008 12:00 PM
With all the talk of #16, why do I need a can.... gb387 Detailing 101 15 Mar 13th, 2006 03:36 PM
Tuner Talk???? Jorge Sanchez Detailing 101 1 Aug 25th, 2005 07:51 AM
Welcome to Tuner Talk! Mike Phillips The Break Room 3 Mar 28th, 2004 09:12 AM
©2004 - 2009 Meguiar's Inc.
