Go Back   Car Care Forums: Meguiar's Online > Detailing - Everything from A to Z > Detailing 101
Detailing 101 New to detailing or just have a question? Ask here!
Reply
Old Nov 3rd, 2009, 05:15 AM   #1
OurJeepLife
Our JeepLife
OurJeepLife's Avatar
Rep Power: 11 OurJeepLife will become famous soon enoughOurJeepLife will become famous soon enough
Question Never Fails: Water Spots
Ok in the past I was able to deal with the effects of hard water spots or stains. But as of late I'm unable to correct some of the hard water spots I've located on the 07 jeep commander.
Bought used and its been well maintained from what I can tell.. The only two issues I'm noticed with the jeep, are the hard water spots and some sort of "running" or "stains coming from the roof top down the back of the jeep.
The stains appear to be some sort of "soap" left behind after a few washings and simply allowed to run down the back of the jeep.. its not bad the longest "run" is about 5 inch long and doesn't even make it to the rear window.
As a person who caters to detail, but my arms are growing tired and less manageable due to two forms of CTS and nerve damage. I need something that I can simply wipe on and off (what rag to use) without allot of force.
I recall something I bought from walmart a few years back and have yet to locate it again. it was something to the effect "orange glow" or lemon glow" and was in a yellow spray can. It was the easiest thing I had ever used when detailing the vette. simply spray on allow to stand for a few mins and wipe off. The product was very similar to a bug and tar remover.
Any direction on these matters would be greatly appreciated.
OurJeepLife is offline   Reply With Quote
Old Nov 3rd, 2009, 08:01 AM   #2
Jossy92
aka Jeff Long
Jossy92's Avatar
Rep Power: 96 Jossy92 is a splendid one to beholdJossy92 is a splendid one to beholdJossy92 is a splendid one to beholdJossy92 is a splendid one to beholdJossy92 is a splendid one to beholdJossy92 is a splendid one to beholdJossy92 is a splendid one to beholdJossy92 is a splendid one to behold
Re: Never Fails: Water Spots
Armorall makes a good tire foam. I heard you just spray it on and walk away. No work.
__________________
Work expands so as to fill the time available for its completion.
-C.N.Parkinson, "....Studies in Administration."
'88 Honda
Jossy92 is offline   Reply With Quote
Old Nov 3rd, 2009, 10:59 AM   #3
OurJeepLife
Our JeepLife
erm.. Jossy92.. I think you responded incorrectly to the wrong post.. try a few doors down for the "ArmorAll Tire Foam" post.. This post deals with "Water Spots"
Old Nov 3rd, 2009, 01:27 PM   #4
Jossy92
aka Jeff Long
Jossy92's Avatar
Quote:
Thank you . But, I was trying to encourage you to use here in this post the same effort that you are able to apply to your tires in the ArmorAll Tire Foam Post.
You know: The procedure of removing the tires etc. that you are looking forward to exploring in your new 07 Commander you just purchased. And the initial scrubbing required the first few times.
Then I realized that it must be something in the Armorall that allows you to use your arms. Hence, if it works so well on the tires, maybe the top?
Today I had to remove some baked on water spots. [Last week I had applied 2 coats of NXT.] Today I dusted it, QD'd it, and then wiped it down with with Ultimate Quik Wax.
Effortless and quick.
__________________
'88 Honda
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Should Meguiar's sell a water spot preventer? akimel New Product Suggestions 9 Jul 20th, 2009 11:53 AM
water spots 911! Gator Rob Detailing 101 14 Jun 1st, 2009 09:36 AM
Water Spot/Etching Removal and Trim Detail (by Hand) volvie! Show Off Your Latest Detail Work 9 Jan 15th, 2009 03:43 PM
Medium or Heavy cut for Rotary buffer for water stains stikman33 Detailing 101 7 Nov 27th, 2006 08:15 AM
should i try gold class??? soft paint steveo3002 Detailing 101 9 Jun 1st, 2005 03:03 AM
©2004 - 2009 Meguiar's Inc.
