Go Back   Car Care Forums: Meguiar's Online > Detailing - Everything from A to Z > Detailing 101
Detailing 101 New to detailing or just have a question? Ask here!
Reply
Old Nov 6th, 2009, 12:22 PM   #1
Simon777
Rep Power: 2 Simon777 is on a distinguished road
Alcohol Stains on Leather Seats
I had some hard to get out marks on my tan leather seats so I decided to gently rub 70% alcohol on them. The marks came out, but where I rubbed the alcohol, the area is now white.
How do I go about getting rid of these white spots on my tan leather?
Simon777 is offline   Reply With Quote
Old Nov 6th, 2009, 12:26 PM   #2
Simon777
Re: Alcohol Stains on Leather Seats
I put some meguiar's cleaner and conditioner on the spots and they did improve, but its still very noticable. Would keeping them in the sun darken the white spots?
Old Nov 6th, 2009, 01:56 PM   #3
Simon777
They are mild stains so I'm hoping there's something I can do about it.
Old Nov 6th, 2009, 10:12 PM   #4
Simon777
If anyone knows anything about fixing leather, I could really use your advice.
Old Nov 6th, 2009, 10:21 PM   #5
Simon777
In case this helps, the tiny creases(pores? not sure what you call them) on the alcohol spots seemed to have been completely cleansed and have no dirt in them(this is really noticable in the first picture with the stain in the upper left corner). If you look at the surrounding areas, it looks dirtier than the areas with alcohol.
If this is the case, is there really no stain? Just that the stained areas are actually just cleaner than the surrounding areas. If so, is there a product I can use to clean the surrounding areas making them the same as the spots cleaned with alcohol.
I used meguiar's rich leather cleaner and conditioner and this was not strong enough to get the grime out of the tiny creases(pores?).
Any advice at all would be greatly appreciated.
Old Nov 6th, 2009, 10:30 PM   #6
roushstage2
Local Roush Master
roushstage2's Avatar
Rep Power: 221 roushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant futureroushstage2 has a brilliant future
I was going to say, those look like clean spots, not stains. It wouldn't even be a stained area, just a clean area. You may need to get a dedicated cleaner and a brush. An APC properly diluted is a good option, and inexpensive considering the dilution of it. A softer nylon brush is what you will be looking for as well. Spray the leather down, let it soak a minute, scrub, wipe with a damp, clean towel and repeat until clean.
__________________
Tyler C.
MOL Mustang Enthusiasts
roushstage2 is offline   Reply With Quote
Old Nov 7th, 2009, 12:19 AM   #7
Murr1525
Murr1525's Avatar
Rep Power: 507 Murr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond reputeMurr1525 has a reputation beyond repute
Yeah, frankly the areas could just be clean. Are those white marks exactly where you rubbed? Or did you clean the whole surface?
I would either:
1. Try more of the leather cleaner/conditioner. Definately want the conditioner after using alcohol either way.
2. You could try more of a 20-30 dilution of alcohol for the rest of the seat, see if it evens things out. Then condition heavily again.
__________________
Murr1525 is offline   Reply With Quote
Old Nov 7th, 2009, 09:28 AM   #8
Simon777
Just to be less agressive, I'll try the APC with a nylon brush. If that doesn't work, I'll give the diluted alcohol a shot. Thank you both. I'll let you all know how it worked out.
Old Nov 7th, 2009, 09:35 AM   #9
Tim Lingor
aka 2hotford
Tim Lingor's Avatar
Rep Power: 1568 Tim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond reputeTim Lingor has a reputation beyond repute
Morning,
When you used alcohol, did you notice any color transfer to your application material??
Otherwise, I would try to clean the leather to see if it is indeed a clean spot or if the color has been removed...
Tim
Tim Lingor is offline   Reply With Quote
Old Nov 7th, 2009, 09:44 AM   #10
Tim Lingor
aka 2hotford
Tim Lingor's Avatar
Quote:
Originally Posted by Murr1525 View Post
I would either:
Morning,
I would strongly encourage you not to use more alcohol until we know if it has actually stripped the color out of the leather. Though leather is tough in most respects, it can be easily damaged beyond repair. Having to replace one or both seats would be extremely expensive!
I would suggest using a dedicated leather cleaner. If that does not solve the problem, I would then contact a leather specialty shop and see what they suggest. While many OEM leather seats are coated, I am concerned that the color may have been pulled out of the leather. It may very well be just a clean spot and I truly hope it is. But until you test the seat with a dedicated leather cleaner, I would not use anymore alcohol.
Tim
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Leather Seats David621 Detailing 101 7 Apr 15th, 2008 12:07 PM
Red leather seats in a 2005 Mustang GT Raymond Interior Care 1 Feb 17th, 2008 12:20 PM
How to Handle My MB's leather Seats? Hook Interior Care 10 Nov 1st, 2005 03:41 PM
How to Treat My MB's Leather Seats? Hook Detailing 101 2 Aug 23rd, 2005 09:22 AM
A 'How-To' on Interior Leather Care Rockpick Interior Care 22 Apr 21st, 2004 06:53 PM
©2004 - 2009 Meguiar's Inc.
