| Hot Topics Please don't start a new threads in this forum. If you have a question, post it in Detailing 101 - Thank you! |
#1 |
I am the paint whisperer.
How much paint are you removing.
How much material (paint) is removed by the various processes of finish care that we perform on our vehicles in our endeavor for that brilliant SUPERIOR SHINE. To demonstrate how much material is removed I acquired a damaged MBZ hood from a body shop that to the best of my knowledge still wears the original factory applied two stage black base / clear coat finish. To perform my test I borrowed a paint thickness gauge from my pal and all around swell guy Brian White (forum name-deltman) This handy little device measures the material between the probe and a metal body panel (primer, base/color coat and clear coat ) in thousands of and inch or “mils� (one mil = one thousands of and inch). It will also measure for body filler and/or evidence of a repair. If you want to buy one expect to pay $400+ for it. ![]() |
#2 |
As you see in the accompanying picture, the black finish on the hood is severely scratched. The surface was also very rough to the touch.
My first reading on the freshly washed hood was 4.2 mils. Now remember that includes everything from the metal on up to the top of the clear coat. Of the 4.2 mils, the clear coat is only 1.5 to 2.0 mils thick. I can only remove .3 to .5 (.5 being the absolute max) or I run the risk of premature clear coat failure. In other words if I remove more than .5 mils I will have weakened the clear coat and eventually have a dull area on my finish. If that happens it will have to be refinished in order to repair it. ![]() |
#3 |
I thoroughly clayed the test area then took another reading. The thickness was unchanged.
I then applied Dual Action Cleaner Polish with a DA set on speed six. I took a reading of the DACP’ed area and I found no change. ![]() |
#4 |
The next step was to machine sand the area with Mirkas finish sander with a 2000 grit pad. A reading of the sanded area read 4.1. I then followed that with a 4000 grit pad and got 4.0.
#5 |
The 4000 grit sanded area could have easily been polished out with something less aggressive but I choose to buff it out with Diamond Cut and a wool pad. That brought the reading down to 3.9.
The hood got a buffing with Diamond cut again but with a W7000 pad this time. There was no change. ![]()
__________________
. . “Freedom prospers when Christianity is vibrant and the rule of law under God is acknowledged.” Last edited by Superior Shine; Jul 31st, 2005 at 04:58 PM.. |
#6 |
I finished the area off with DACP applied with a DA then topped off the finish with NXT. My final reading was still 3.9. The total mils of clear removed are .3, well within the “safety zone�.
I understand that many variables can play apart in the readings I got. The same procedures performed to another vehicle may not remove as much material or possibly more. Things such as paint hardness, pressure applied to the finish while I buffed, the number of passes with each product, etc, all come into play. But this little test hopefully will give you an idea what is going on to repair a defect in the finish. Now it is time to clean up the mess. I made. ![]() |
#7 |
aka 2hotford
Excellent write-up, and test Joe!!!
Tim
__________________
Tim Lingor's Meguiar's Product Reviews |
#8 |
Thanks
Joe
Great demo, super information... Thanks for sharing you skills with us. Bill P. |
#9 |
Thanks for doing that test! It was very informative. Is the clearcoat thicker on a Mercedes than on American cars? Is the clearcoat thicker?
That would be the perfect hood with which to learn rotary buffer use. I noticed the lack of orange peel on the hood too. RamAirV1 |
#10 |
Great test and info. This did bring up a few of questions.
Did you notice very much surface correction using the 9000 pad? I'm curious how much paint correction occurred if little to no paint was removed as read from the gauge. Can you repeat this test on a domestic body panel? I've read that German paint is some of the hardest paint to cut/buff out surface defects. What determines how many readings and locations to obtian readings when using the paint thickness gauge? Knowing how I am, I'd take a reading every couple of inches and spend more time measuring than buffing! How does that Gauge work for fiber glass body panels? 4 down 16 more to go!! Thanks again for the test and results. Very helpful. That little gadget seems handy and easy to use. |
| How much paint am I removing? | manueljlg | Hot Topics | 49 | Jan 23rd, 2009 03:13 PM |
| removing paint | vietkangta | Detailing 101 | 2 | Jun 9th, 2008 09:56 PM |
| Removing paint-pen | JoesSHO | Detailing 101 | 1 | Mar 14th, 2007 09:48 PM |
| Removing Paint | lablover | The Dual Action Polisher | 3 | Jun 13th, 2006 03:43 AM |
| removing Spray Paint | russell336 | Detailing 101 | 6 | Oct 11th, 2005 08:03 AM |
