| How-To Articles Please don't start a new threads in this forum. If you have a question, post it in Detailing 101 - Thank you! |
#1 |
How To Remove Water Spots
How To Remove Water Spots off Automotive Paints
Swirls, scratches and water spots are the three most common paint defects car enthusiasts struggle with when it comes to removing them and preventing them from coming back. In this how-to article we'll take a look at water spots, where they come from, how to remove them and also how to prevent them. There are two basic kinds of water spots or water marks found on automotive paints.
Type I Water Spots are what Meguiar's refers to as Above Surface Bonded Contaminants. A Type I water spot is some type of deposit, often times a mineral deposit that was suspended in the water source to begin with, then after the water evaporated off the finish the mineral is left behind where it bonds to the finish usually in a circular or pattern or shape. Type I Water Spots - Mineral deposits sitting on top of the paint ![]() ![]() How to Remove Type I Water Spots If you discover Type I Water Spots on your car's finish, it will often times require the use of both detailing clay and a paint cleaner to completely remove all trace of the mark left behind.
Type II Water Spots - Etchings below the surface Type II Water Spots are what Meguiar's refers to as Below Surface Defects. A Type II Water Spot is actually an etching in the surface where whatever was in the water was strong enough in its chemical composition to actually eat or dissolve the paint and thus etch into the paint. Type II Water Spots - Etchings below the surface ![]() Close-up of same photo above ![]() If you discover Type II Water Spots in your car's finish, you can use a paint cleaner by hand such as ScratchX and the procedure outlined above in Step 3 for removing below surface etchings left by Type I Water Spots, or you can use a machine applied product such as a Meguiar's paint cleaner, or cleaner/polish to remove the water spot etchings using Meguiar's G100 Dual Action Polisher. Meguiar's Dual Action Polisher will safely clean your car's finish removing a small amount of paint in an effort to level, or smooth-out the paint. The goal is to remove just enough paint to level the upper most portions of the surface with the lowest depths of the defect you're trying to remove. In some cases you may want to check with a seasoned professional for their advice before attempting to remove below surface defects like Type II Water Spots. Important Note: Anytime you use detailing clay and/or a paint cleaner on your car's finish, you need to reapply a coat of wax to the paint as detailing clay and paint cleaners will remove any previously applied wax off the paint. How to prevent water spots from coming back There are two important things you can do to help prevent water spots from coming back, one is to remove water from the finish before it can dry and potentially leave a water spot. Meguiar's offers a number of different tools to help you do this including, our waffle weave Water Magnet Drying Towel, our Soft Touch Microfiber Chamois, and our Premium-Natural-Chamois which comes in 4 different sizes. Besides keeping water off your car, the next best thing you can do is to keep maintain a good coat of wax on all the painted surfaces, to help with this Meguiar's offers a number of different waxes to suit everyone's preferences including, NXT Generation Tech Wax, Gold Class Liquid Wax and Deep Crystal System Carnauba Wax.
__________________
#2 |
Hey Mike, thanks for the awesome writeup about removing waterspots from paint. Do you have any advice about removing stubborn water spots from glass surfaces? I'ved tried several things such as rubbing compound and many of the products you listed above but I just cant seem to get the glass as smooth as I'd like. Thanks!
-Rob
__________________
-Rob Mariana Blue Pearl 1994 Mitsubishi 3000GT VR-4 310 AWHP 326 AWTQ @ 15psi http://www.vr4rob.com/ |
#3 |
Re: How To Remove Water Spots
Ever try distilled vinegar?
#4 |
Sometimes distilled vinegar will remove some of the mineral deposits, but it's never a sure thing.
The two methods outlined above are sure things. After washing a car if you find water spots in or on the paint, first this means that washing didn't remove them, thus you're going to have to move on to Plan B. Plan B is to determine if the water spots are above the surface and are in fact deposits, which sometimes vinegar will remove them, or at least some of them, or if the water spots are in fact holes in the paint, in which vinegar will do nothing. The article above is pretty detailed in what the two different types of water spots are,
Often times even after you remove deposits that have bonded to the paint the deposits will leave etchings that will have to be removed with ScratchX or some other type of paint cleaner or cleaner/polish. Mineral Deposits on the paint - Type I ![]() There is no way in the world vinegar is going to remove the paint around this hole or etching in the clear coat; the only way to remove this is to remove the paint surrounding the etching using some type of paint cleaner or cleaner/polish. Water etching below the surface - Type II ![]()
__________________
#5 |
You know, water spots are like a sun burn - it's best to prevent it than to treat it. But then, if everybody took excellent care of their cars then I'd have to find another second job as there would be no need for detailers. Mike, I wasn't trying to second guess you, just there's all that (start with the least aggressive polish/pad/cleaner etc) I just thought before you got into a war with water spots - to try distilled vinagar, my method is to saturate an old MF towel and let it soak on the spots for 5-10 minutes and then scrub it. It's worked for me, but then, I didn't have that "paint cancer" that you showed in your pic to deal with either.
[Edited for implied bad language. Please keep language family friendly; Thanks, 2hotford] |
#6 |
hi Mike thanks for tip, I'm just new here but im loving every second of it. Thanks for sharing this articles. Albert.
__________________
my window cleaning service |
#7 |
I had to travel for work and was away for two weeks. To make things worse the car is black. I have tried to polish the spots out already. I am guessing that I did not use a polish abrasive enough. What polish would be abrasive enough to get rid ofthe spots?
#8 |
Oh yeah. Thanks for all the help guys.
#9 | |
Quote:
Most people think the paint on their car is soft, and in most cases it's hard, and that means it's going to be hard for you with your 4 fingers pushing down on an applicator pad to remove small particles of paint in and effort to level the uppermost surface with the lowest depths of the water spots. Didn't know if you knew this? ![]()
__________________
#10 |
If I have water dried on my paint I get some spots, but I have never seen any that wouldn't come of after just using a normal car wash. I guess if you have water that is not very clean or the sun burning it in to the paint or a surface that is not protected with some sealant or wax, it might be different.
| should i remove water spots??? | sudsbyhubbs | Detailing for dollars | 9 | Aug 30th, 2008 08:14 PM |
| M85 - Can Be used To Remove Water Spots From Glass? | poyo | Professional Line | 16 | Jan 30th, 2007 03:35 AM |
| How to remove calcium water spots below the surface | mirrorfinishman | Detailing 101 | 3 | Apr 7th, 2006 11:05 AM |
| Water spots...how to remove? | cardinal78 | Detailing 101 | 0 | Jul 8th, 2005 02:32 PM |
| How To Remove Water Spots | Mike Phillips | Detailing 101 | 11 | Jun 23rd, 2005 04:52 PM |
