whats the differnce between the pc 7224r and the 7336spr ? which one is better in your opinion ?
which polisher ?
Meguiars G100A Polisher - Lifetime warranty, 5 ounce counter weight, one backing plate and one pad is included - Meguiars G-100A
Porter Cable 7336(considered a sander) - one year warranty, 6 ounce counter weight and you will have to buy the Meguiars DA Velcro Buffing System(contains: one backing plate, two soft buff polishing pads and one soft buff finishing pad)
Porter Cable 7424(considered a polisher) - one year warranty, 5 ounce counter weight and you will have to buy the Meguiars DA Velcro Buffing System(contains: one backing plate, two soft buff polishing pads and one soft buff finishing pad)
All three machines(the power unit itself)are basically the same. You need to get Meguiars brand pads if you go with either Porter-Cable (7424/7336) version, do not use the included white pad.
The two different counter weights won't make a difference, here is a test "Jimmy Buffit" did: The Dual Action Counterweight 'Controversy'Last edited by gb387; Jan 24, 2006, 03:45 PM.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
I have both PCs (one of each part number) and they're absolutely identical except for the included backing plate and counterweight.
FWIW, I've had a different experience with the weights than Jimmy Buffit; I find the 6" counterweight cuts down on vibration. I find the combination of heaviest counterweight (6") and lightest backingplate and pad to work the best. Note that foam pads (especially when loaded with product) weigh a lot more than the single sheet of sandpaper the machines were designed to use (the basic machine was designed as a sander, the polishing application came much later and they didn't change the innards of the machine to accommodate this).
Don't worry about which one you get, go by price or warranty (e.g., the g-100 route through Meguiar's). You might need that warranty
I use the 6" counterweight with every size pad (even the 4" ones). The PC part number for it is 699933. Only costs a few bucks. The PC phone number is 888 848-5175.Practical Perfectionist
You could call PC and get the parts from them, but I'd just find a local PC repair place and let them do it (they rebuilt my older one). Most medium-size cities have one as a lot of builders use PC equipment.
One of the best reasons to go with name brand equipment is the after-sale service support.Practical Perfectionist
There are several tool "hospitals" around my town and they all do a very nice job, all the name brands are easy to find parts for.Brandon
