I was just curious is it safe to use apc as a wheel cleaner dilluted 10-1 or 4-1 the reason i ask is that I go through alot a wheel cleaner have 4 cars that like to stay clean. Is it safe to use as an all wheel cleaner? What dillution? I also have safe degreaser but i dont know about it on rims? I usually try to use soap and water but the cars other then mine dont get cleaned as much as mine adn have pretty bad break dust. Any opinions? Thanks Greg.
APC as a wheel cleaner
I'm sure it'll work fine, but I don't think it'll be as strong as say wheel brightener. That's definately better than using degreaser.
Give APC a try on a bad wheel for testing. If it works ok then you should be fine. In my experience APC can clean anything, but it's best to stick to products that area geared to a specific thing than to expect chemicals to have multifunctions - this in the end can pose long term damage if you can't see it right away.
Another note - I'm not sure if APC can do a good job with brakedust w/o ruining the clearcoat. Won't know till you try a test spot in an inconspicuous area.
Good luck and let us know what you decided on.2001 Vortex Blue New Beetle
well today when i washed the car i used apc on the wheels and safe degreaser on tires i used apc 10-1 on the wheels. I tried it before on my moms car when i ran out of megs all wheel cleaner i just wanted anyones opinion on having any kind of bad effects wheel brightner seems to dangerous and i wouldnt want to stain the wheels but apc seemed to do alot better then car soap any input would be great. Greg.
Re: APC as a wheel cleaner
There is no effect from using APC 10:1.I used it on many cars.From wheels to doorjambs to dead bugs on the front end.The problem with APC is its not aggressive enough on heavy brake dust.then you really need a Specific wheel cleaner.Judging by your T-Bird youll be fine.Good looking car.2007 Mustang GT/CS white 5sp. named Cali
Show Car Detail
