Some of you guys use Power inverters. I need Help in how to conect my Inverter, Do I need to conect my Power Inverter direct to the battery of my car , Please if some one can helpme out . My power inverter is 1200 watts.
Power Inverter I need some Help ....
Re: power inverters
Originally posted by damonswank
pleqse contact me for info
best alternative is West Marine: the boaters use inverters
damon swank
Now you mentined something about a website protocol? can you be more specific, about that matter!
Thank you once again.CAUTION : Auto Detailing is addictive. It can be very difficult to quit. " CAR CRAZY " (Serious car care people)
Hi,
i have two power convertors. One is 400watt and the other is 900watt. The 400watt comes with a cigarette lighter connector and a normal hook to a battery. In the manual , it says if you use the cigarette lighter connector, make sure you don't exceeds 175watts or you will burn your lighter fuse. Above 175watts, it recommends to be connected directly to the battery. I have used both methods and they seem working fine with me.
On the other hand, the 900watts comes only with battery hooks.
I have also used it and it is working fine with me.
I only switch on the car every while so the battery doesn't die on me.
Re: Power Inverter I need some Help ....
I purchased a Husky 750 watt inverter from Home Depot today so I can detail my truck in peace (I live in an apartment complex) . I'm thinking of purchasing one or more batteries and a charger, for a power source especially for detailing.K3AKE 147.555
