Here's the plan. I wanna strip my car of all its wax and start over from the beginning.I am gonna clay my car as soon as i get a few days of consecutive sunshine. I have Meguiars Deep Crystal System Polish, NXT paste wax, and i am about to go buy some kind of sealant/glaze stuff. In what order do i do all this? How long should i wait before applying the different steps? Also, i plan on doing all of this by hand. What kind of applicator should i use, a microfiber or a foam one? tia.
When do I apply what?
to MOL
yep first you want to clay (after you have washed) then use a paint cleaner like DC step 1 then go to you DC step 2 polish. With DC1 and DC2 you can wipe then off right after you are done working them in. If you let it dry it will be hard to remove!
then wax with the NXT do one coat of the NXT, remove with a microfiber, dont expose the paint to any water for 24 hours and do another coat and boom you have a show car shine!
i cant tell you which applicator to use but both should be fine i use faom because it is all that i can get
heres some good reading:
How to tell when a Meguiar's wax is ready to remove - The Swipe Test
The 5-Step Paint Care Cycle.
Step 1 Wash
Step 2 Clean
Step 3 Polish
Step 4 Protect
Step 5 Maintain
NXT Tech Wax Cure Time
A Question on Wax Bonding and the Potential of Interference by a Quick Detailer
What's the Deal with "Layering"?Patrick Yu
2003 Honda Accord
2008 Honda Accord EX-L V6
you already have NXT which is pretty good 2 coats should make you car look wet!
if you are really obsessive you can order M21 which looks amazing too just do a search for M21! good luckPatrick Yu
2003 Honda Accord
sealant/wax goes after the polishing step
reading this might explain it(they are pretty much the same kinda thing)
Synthetic Polymer/Sealant vs. WaxPatrick Yu
2003 Honda Accord
Dont worry, it may take a little while to get used to Meguiars terminology, and not confused between other companies terminology.
Meguairs tends to mix and match some terminolgy sometimes, so wax=sealant, and polish = glaze.
Other companies use cleaner/ polish/wax/sealant/glaze to mean all kinds of things, so just try and stick Meguiars terminology in your head for now.
Wash
Clay
Cleaner
Polish
Wax2017 Subaru WRX Premium - WR Blue
Originally posted by GigEmAgs07
should i do two coats of polish too, just to make sure i get an even application?
Be sure to read the entire 5-Step Paint Care Cycle, I wrote it and it's fairly exhaustive on the products and procedures, it contains a lot of information that will help you understand what your doing and why you're doing it.
