A guy at work asked me to remove some "rail dust" from his newish RX330. So I brought my PC and some Meguiars stuff to work with me and I was able to clean the sides of the car easily with some Deep Crystal Cleaner. But the back is aonther story it has a SEVERE case of "rail dust", will calying remove this? I have some #9 2.0 as well or will I need something stronger? I only trust myself with a PC is there something I can do with the tools I have?
"Rail Dust" removal?
Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Meguiars Online Acronyms - Meguiars Product List....Tags: None
I am no expert, but I have clayed three different vehicles. I believe it the single most important thing you can do to make your car or truck look the very best it will. I did my landloards truck this past weekend and you didn't have to feel it, you could see the contaminates. It is a 1986 chey farm truck. Here is a picture.
After I clayed it.
This was after using DC#1, Paint Cleaner. I have more pictures and I am planing on writing a makeover but haven't gotten around to it yet. Takes so long to upload pictures one at a time.
Anyway if your car has never been clayed do it, you won't regret it.2005 Trailblazer LT Majestic Red Metallic
AutoGeek's 6th Annual Detail Fest & Car Show
1st Place-Best Overall Detail
3rd Place-Best of Show
March 26th, 2011
There are a few cutting powers, D6100- Mild clay and D6200 Aggressive clay. One of these should work for you. Remember to use the proper lubricant. The end result should feel smooth as glass!You learn to become Great, by doing what other Great people have done before you.
Originally posted by 2hotford
Hey,
Yes, I would suggest using Meguiar's Overspray Clay (C-2000)with lots of lube ( Meguiar's #34 Final Inspection) to remove the rail dust.
The 1st time I ever used clay, I couldn't believe how slick it made the paint feel...I was never really able to equal that slick feeling with a PC.r. b.
Clay is the absolute best method to remove rail dust! The Overspray Clay would be a good choice. I use the white OC, is that the more or less aggressive version?
Using a cleaner and a PC to remove rail dust should only be done if it it VERY light. Otherwise it won't work very well and you would have to use a rotary and you wind up removing quite a bit of paint.
If you can't find the Overspray Clay, go to Autozone or other auto parts store and get a Clay Magic bar (blue). It works very well and doesn't require large amounts of lube. It comes with a spray bottle of lube which works pretty good.
RamAirV12015 Dodge Charger R/T Scat Pack 392Granite Crystal
2006 GTO Impulse Blue
Hey RB,
Yes, I have tried Final Detail for clay lube. But I prefer the #34 Final Inspection as I found the FD a little too slick/slippery when claying. I really try and feel what the clay is doing, and FD made the surface so slick, I could not do that. Just a personal preference!
However, as a QD, there is nothing better than FD to bring out that little extra from the finish!! Just IMHO!!
Originally posted by FlaresideLariat
Is there anything negative about the aggressive clay bar? (D6200)
Another example would be using a compound to do the job that a light polish would handle (like using #84 when #9 would've worked). Obviously, the #84 being CONSIDERABLY more aggressive would potentially cause issues that you might then have to follow with #9 or something even more aggressive to remove something that would've been originally dealt with the #9.
Personally, I'd recommend going with the mild bar as I believe you'll find that it'll do a great job. Yes, you may have to go back over an 'ultra-tough' area once or twice but, in the end, it's ultimately a safer product to utilize in my opinion. It's what I use.
RP
It is important to realize that most IFO contaminants penetrate the clearcoat. Assuming that's the case, buffing tends to 'chop' off the protruding particles, leaving ferrous material in the CC. That is a great breeding ground for rust (yellow spots).
On the orher hand, clay actually pulls the particles out. Apart from some smearing, I can't think of a downside to using clay...
BTW, rookies should try a baggie, fingertips inserted, on a well lubricated surface. Try it b4 and after claying. You'll say "Wow!"
Jim
Hey RB,
TimLast edited by rusty bumper; May 14, 2004, 08:03 PM.r. b.
JimFL
