SHow Car Glaze - Before or After Wax?
  • SHow Car Glaze - Before or After Wax?
    I always thought show car glaze was used before waxing. I just saw somewhere where they recommended it after waxing. What is the correct application order??
    Show car glaze #7 is a pure polish and you have to seal it with a wax in order to last more time so, I don't know where you saw that but yes you need to use it before waxing.
    first: show car glaze #7.
    second: wax or sealant
    ayudando a los regiomontanos a que sus autos brillen waldo_gomez@hotmail.com
      I've used this product for years. I always use it before waxing. I also use it after waxing just before I bring a car to a show. I love the oily-wet look and it has turned a lot of heads at the shows. Of course, it doesn't last long if applied after a wax.
      Jim
      My Gallery
        This is what they were referring to. Using the glaze as a car show head turner. I assumed the glaze would remove the wax though.
          #7 Show Car Glaze is a pure polish and non-abrasive.
            If applied on top of wax/sealant, the Show Car Glaze will wear off very quickly.
            However, people with show cars, or going to a show will sometimes do this, putting #7 on top of wax/sealant, as some people find it gives a little more pop to the paint.
              Can I put #7 on the day before a show that I have to drive 100 miles to get to? If I go over the car with a QD will I lose whatever extra pop #7 gave me?
                No, it should be just fine. I would not worry at all. Once you get to the show, apply a coat of Last Touch and you should be good to go!
                  I've heard of some in this area that don't use anything but #7.
                  r. b.
                    What is the difference between #7 and the Step 2 Crystal Pure Polish?
                    /Keith
                    2001 LT Tahoe | Hybrid Wheels - Depo Headlights with DDM HID's (55w @ 4.5k) - Clear Corners - Sonar LED Tail Lights (Red Smoked)
                    www.LakeMeadOnline.com
                      There's a difference, but my experience is that it's not enough that I'd recommend going out and getting #7 if you already have DC2. DC2 is easier to work with and gets you close enough to the #7 look that almost no one could tell the difference.
                      Mike can tell you more, but my guess is that DC2 is thinner (making it more consumer level friendly), a newer formula, and is maximized for clearcoats.
                      Tom
                        Meguiar's #7 Show Car Glaze contains the highest amounts of TS Oils. It was created a long time go when SS paint was the norm. However, it works very well with BC/CC paints!
                        DC#2 contains less TS Oils, is a little easier to remove, and performs very similar to #7.
                        Cheers!
                          Tom
                          Cheers!
                          Alright thanks. I noticed when I was applying DC#2, it was not as runny as the #7 was. And was a lot easier to remove. I had heck of a time removing the #7 when I used it.
                          /Keith
                            Removing #7 is a bit more involved than the other polishes that Meguiars makes. Here's a great writeup by Mike P. that explains it in great detail....Just scroll down a bit to find it....
                            r. b.
                              http://www.meguiarsonline.com/forums...show+car+glaze
                              Thanks for the link.
                              /Keith
