Wheel Adapters...HELP!
  • Wheel Adapters...HELP!
    Okay guys...so I bought some rims. They only cost me $100 dollars...total...so I took them. But it turns out the bolt pattern is larger than my stock bolt pattern. The offset on my car is 32 but the offset on the rims is 42. Can someone help me figure out what size wheel adapter I need?
    If there are any questions so you can help me out that'd be awesome. Thanks in advance!
    Real Name: JD
    Car: '03 Indigo Ink Toyota Matrix XR, Pretty much stock...
    If i where u i am give Eibach or H&R a call in regards to putting spacers for your car. The 42 offset on that rims simply means that the wheel is closer to your hub. i would imagine a 10mm spacer from either both company would do the trick for you. Both company sells spacers/including longer studs. I might cost you a pretty penny for a set. The 32 offset on your car means that the wheel is pushing outwards/outside versus the 42 which is inwards/inside.
      Ah. Thank you. I know that my bolt pattern is 5x100 but I can't figure out what the bolt pattern size is on my rims. Is there any way I can find out?
      And thank you Jason
      Real Name: JD
