New to detailing. Polishing questions.
  • New to detailing. Polishing questions.
    Well I'm going to do my first real detail with polish and everything as follows:
    NXT Wash
    Quick Clay
    #9
    Pro Hand Polish
    NXT Tech Wax
    In that order. I was wondering about how you apply and buff the polish. What's the difference between the finishing pad and the polishing pad? After I apply the polish do i just buff it out with a MF towel? Finally, Do I let the polish sit there like a wax or do I whipe it off immediately? Thaks for your help.
    Good process!
    I would work in the #9 more so than the polish. #9 by machine. I polish by hand.
    Finishing pad is for waxing or appling a polish such as #9 so as not to mar up your surface after other more aggresssive products are used to remove swirls. Polish pad is a bit more aggrressive to work in more aggressive products (like #82 swirl free polish, #83 DACP).
    Pro hand polish I would spread even coat on a single body panel then remove bulk with terry while wet, and finally buff to shine with MF. I've had problems removing if I let it set and dry.
    Good luck
      If you are using #81 you will really like it its my favorite polish hands down... as scrub said never let a polish dry or you will had a hard time removing it. As recommended to me by someone on here, I have applied #81 with the PC and Finishing pad on a speed of 3.5-4 and had very good luck.
      Brandon
      2007 Black Chevy Avalanche
      My Albums: Avalanche
