claying
  • claying
    How often can you clay a vehicle and not hurt the paint? It seems after you do all the steps the smoothness doesnt stay but about three weeks not as smooth as glass.. Also will scratch x remove swirls by hand or do i need a buffer and if i need a buffer is there a cheaper one than the g100 that will do the job. I have a new black truck it looks great except for the occasional swirl marks that the dealer put in. Or am i being to perfectionist.
    No such thing as a perfectionist around here. Though a realist is ok.
    How often you need to clay can depend on many things. If you live near factories, train tracks, other industries that might be putting heavier pollutants in the air. Stuff falling off trees like sap, etc. People being careless painting. Etc, etc.
    Which wax are you using? How often are you washing?
    All you may need is to use a Quick Detailer/Speed Detailer, or a spray wax after washing to get the slickness back.
    How to Get Great Results Using Meguiar's Spray Waxes
    As far as swirl removal, yes, ScratchX can do it by hand. It is a pain though. Here are some links on how to do it:
    How To Remove Swirls By Hand
    Now, you will get better results, and quicker/easier with the G-100. Here are some liks for it:
    And to make sure you have what you need for a new car:
    Suggested Products for Taking Care of a New Car
      i used the clay the deep crystal paint cleaner the deep crystal polish and the nxt wax I tried the spray wax after i washed the truck one day and it was very hard to get off i may not have let it dry good enough because it looked like it was gonna rain it seemed to smear and took a lot of pressure to remove i am gonna try it this weekend and see what happens.
        Yes, Nxt Wax gives me very similar results. Keeps a nice shine, but seems to lose its slickness.
        I have switched to #21, which seems to stay slick longer. But your environment could change that as well, if lots of stuff lands on the car, etc.
          I'm about to detail a car that was parked in a paint shop. The car is shiny and all but upon closer inspection and touching, it is covered with paint dust (overspray?). Is this a job for claying or merely compounding? Please advise. What's the best approach to this? Thanks.
            Claying is the first step no matter what, and is also good for overspray. Espeacialy fresh overspray.
              Thanks a lot.
                Re: claying
                Claying is non-abrasive. It simply removes the bonded contaminants from the surface of the paint and "eats" them. As far as I know, using plenty of lubricant (like QD) you could clay forever.
                - Ben
