How to work the #80 using a 8006 pad
  • How to work the #80 using a 8006 pad
    I used the #5 speed with the PC and the 8006 pad on my practice car to work the #80. However I'm not getting the results anticpated.
    I don't think I'm working long enough or hard enough. How long should I work a 2'x2' section? And do I have to press down on the the PC or let it work under its own weight? How do I know when the #80 is fully broken down?
    Try reading through this thread...
    It took me a couple times to get it right but now i think i got it down when i saw that i removed scratches off my moms hood. Hope i didn't just jinx myself either
      Re: How to work the #80 using a 8006 pad
      Best thing you can do for yourself is pick up the DVD on the PC and you'll get awesome results... here's a link to where you can pick it up.... I did and after using the PC for over a year, I learned a ton that helped me get much better results.
      • Edit: Weird. I have to edit out a link to my own DVD -Mike Phillips
        (Do a Google search for ShowCarGarage and you can find the DVD if you're interested. )
      Bill Poirier
      West Seneca, NY 14224
        yes get the DVD. you'll learn so much in 2 hours. well worth the 25 bucks.
          I don't have the PC...yet , but I did buy the DVD for it. I have learned alot on removing swirls and to properly applying wax. I can almost smell the polishes and waxes being applied with that PC. You can't go wrong with the DVD...I promise!
          2016 Focus ST
            Just to note, the DVD mentioned in this thread isn't a Meguiar's DVD, it's a Mike Phillips/Richard Linn/ShowCarGarage.com DVD.
            That said, I'm still held to the same forum rules as everyone else and thus I've removed the link to the page where our how-to DVD can be purchased.
