What's the difference(if any) between #7 show car glaze and #5 new car glaze? I've been using #7 for years, but also saw #5 at local Riebe's store.
Any difference?
#5 is formulated for warmer climates (whatever that means). I have both. #5 is green and smells different than #7. I find it dries faster, meaning you need to remove it quicker after application. #5 is a younger cousin to #7. You wouldn't benefit from having one over the other, though people will probably tell you 7 is better. This is one of the problems with Meg's--too much stuff. They keep the old stuff and at the same time, replace it with new stuff.
# 5 and # 7 both fall into the pure polish category. While they are similar they are also a tad bit different.
#7 pure polish designed for hand, orbital, p/c application
#5 pure polish designed for hand, orbital, p/c and rotary application.
The biggest difference in the two is # 5 was designed for "humid" climates, which means, it tend to dry a bit quicker under high humidity conditions. When you have high humidity, # 7 can be a bit difficult to remove, therefore the launch of # 5...
But keep in mind, if your in a dry area (maybe AZ for example), you will definitely want to use # 7 because #5 would dry too fast !!!
We hope this help clear up the 2
Mike Pennington
Meguiar's, Inc.
800-854-8073 mpennington@meguiars.com
